Door lock Hi I cannot open the door on my hotpoint WT940 washing machine. Any ideas please?
    Scholar:
  • 150 Answers
The lid switch assembly has a latch to prevent opening the lid in spin (it hooks through the stirup on the lid) you can get into it by inserting a thin screw driver into the crack between the top and the front panel and pushing in on the clips located at both sides you can see the clip it is ca. 1 inch wide about 3-4 inches in from the side just push in and lift then get the other corner.
lift up the top and you can access the latch assembly
Posted on May 08, 2008
    Novelist:
    Champion:
  • 244 Answers
Theres 1 way u can open it and thats un-plug the washer take the lid off now put your hand down the front of the inside of the washer on the side that the door lock is if u feel around on the interlock theres a small catch that comes through the hole push it and it will open the door this catch is fixed to your door m8
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
The door is jammed and wont open after washing.
Please follow this link. It is a short video for a Hotpoint washer, but the idea is the same. Thank you! Opening locked washing machine door
Jul 01, 2015 | Bosch Washing Machines
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
Hotpoint wt940
the door is not locking , possibly caused by the interlock itself or motor brushes worn ( most likely if machine is a few years old at least ) could also be no power to lock via control board .
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima wt940 I load washing and set a normal program (say 40 degree wash). The door is firmly closed. I push start. Even though the LCD is on and I have pushed start - there is no...
'door' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
