Hello. I have the HDTV ready hookup for my xbox so all i have to do is switch it from tv to HDTV and it will switch over. My hookup has a green, blue, 2 red, 2 white, and a yellow hookup. i hooked in all of them but my lines show up. it is like a white libackground and green and blue lines flash up and down. when i switch the switch from HDTV to tv i get a perfect picture, but its not as nice because its not HD. I have used this xbox on another HDTV and it worked fine. i dont know why it wont work on this one.
  • 4,924 Answers
Pay attention on how you hook them into the xbox..and if you are sure this is the way ..than switch to another HD input on the tv ...usually they have 3 HD channels..but not all work ...cause ar eon different frequencies or something like that ..Just try them all ..be sure you make the right choice in the channels too on the Hd of the tv ..
Posted on Aug 28, 2010
Screen blurs when conected to xbox 360
Hello depending on what type of input u use there is a switch on the cable nearest the cable end that is labeled TV and HDTV if you are using all five cables to connect the xbox then put the switch to HDTV, if you are useing the yellow, red, and white then put the switch in TV mode.
Oct 21, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Is it possible to hook up an slyvania to hd on xbox 360?
hello. You can get an hd signal if you have either of two connections on your tv. One is component hookup (red blue and green jacks). The other would be an hdmi port. If you have the proper cables for your xbox then it is possible.
Apr 06, 2011 | Sylvania LC320SLX 32 in. LCD TV
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
My xbox 360 wont start up, the light on the power box is green and there is no red circle of death , it just wont start up :*(
well if your 360 green light is on and the green light is on the battery box your AV cable is broken a new one is 10 to 15 dollars or if you have a old tv you might have the tv switch set on HDTV or if you have a HDTV it might be set on tv. i hope this helps your problem.
Dec 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
Green color screen
your hdtv cables are wrong color match them to the input on tv
Nov 09, 2008 | Philips 55PW9363 55" Rear Projection...
No Sound on Xbox 360
Very often on HDTVs there may be more than one YPbPr connection... That is the Red Green and Blue. Under each one, or next to, or above, there should be separate red and white audio hookups for each set of YPbPr hookups.
Make sure they are hooked into the corresponding plugs.
Hope that helps.
Jul 15, 2008 | Microsoft Xbox 360 Console
Xbox360 hook-up
do you have component outputs from your xbox if so read the instructions and set tv in put to component or hd input if you choose to use them the set will auto adjust for the input and you might still have to enter the menu settings,
Dec 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Computers & Internet Logo
David Payne
David Payne
