Hayward h-350 won't ignite? - Heating & Cooling
  • 70 Answers
Does it have a standing piolt and is it elec ing. Here is a copy of the service/install manuel
http://www.haywardnet.com/products/manuals/pdfs/Manual183.pdf
Posted on Aug 28, 2010
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Ignition won't connect
try looking for the hidden fuses by following the wiring i had the same problem i traced and found a hidden fuse that haqd blown
Jan 17, 2013 | Yamaha Bruin 350 4x4 06 Airbox Air Box
My mercedes ml350 won't sart..when i turn the ignition it makes a sound but the engine won't start
I don't know if this is helpful but an engine needs three things to work. Air, fuel, spark.
Jan 15, 2013 | 2006 Mercedes-Benz ML 350
IF error code on Hayward H150FDN
flame sensor if stands for ignition failure
May 16, 2012 | Hayward Pool & Spa
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
I have a Hayward ABG100 pool heater that won;t turn on. I hear a faint click when I turn it on but no blower or ignition to follow. Power and flow are fine. Is this a bad ignition module?
It sounds to me like you're looking in the right direction with the ignition module.I would replace it and then see what happens.Thank you
Jun 20, 2011 | Heating & Cooling
I have h series milvolt 350 k started heater up ...
The bypass assembly inside of the header has failed. It will need to be replaced. I would also replace the internal thermostat while you are in the header.
May 20, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
May 25, 2009 | Hayward Pool Products Hayward 400k Lp H...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
