Question about Asrock M266A Motherboard
Pc does not boot
My pc is asrock m266a board intel pentium 4. it does not boot nor reach to bios startup nothing shows on the monitor ketbord and mouse are off only the fan runs i tried to take everythin out and assemble it again no results found pliz help . moses
  • jhovenn Aug 13, 2008
    Same problem. Change the power supply already, same result.
  • Anonymous Oct 15, 2008
    same problem, to replace Power doesn't NOT resolve the problem.
Posted on Oct 02, 2008
I think that it will be a broblem if there is no beeb from the mother and u will have to upgrade ur bios by one or more method but i suggest to get a help from ur technical support
Posted on Aug 28, 2008
You try replese the transistor..........B1224 AND YOU WIIL...CHANGE IT...BY USING HOT AIR.....ELECTRONIC GADJET..THIS GADJET ARE USED OF CELLPHONE...TECHNICIAN...
Posted on Jan 06, 2009
    Scholar:
  • 172 Answers
Dead motherboard, replace this and all will be fine.
compdoctor2005@btinternet.com
Posted on Nov 23, 2008
  • 106 Answers
LOOKS UR SMPS (POWER SUPPLY UNIT IS FAULTY.
ARE U GETTING A BEEP WHEN U START THE PC? I HOPE NOT.
SO CHANGE UR POWER SUPPLY UNIT AND THE THINGS WILL BE FINE.
Posted on May 07, 2008
I want to upgrade my current processor (Pentium 4 531 3.0Ghz Prescott with Hyper-Threading) from my ASRock ConRoe865GV motherboard to Core 2 Duo E4xxx series or Pentium dual core E2xxx series. But I want...
hello velayojoel
my name is ausi.
if the asrock web site says 2gig is the max then that is it. the only other thing to check on their web site is the bios version. see what version is your bios and if a bios upgrade can help. otherwise the only thing to do is to replace the board if you want higher processor speed.
hope this has helped somehow.
good luck
Feb 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have no maother driverboard of m266a board
at asrock there are two models. M266A and the M266A R3.0
If you boot it - in the bios setup it should tell you the model.
here is the link. (put the WWW. before it.)
asrock.com/mb/index.asp?s=Search&k=M266A
Good Luck.
Bill
Nov 29, 2010 | Asrock M266A Motherboard
P4I45GV R5 Motherboard: i have intel 945g motherboard the cpu fan runs but...
Check you Ram. If possible, try with another working ram. Clean the port. It is also possible that your cpu is overclocked, remove the bios battery and leave it outside for few minute and reinsert it and boot the system. If this doesn't helps, you'll need to check your display card also. Try the monitor on another pc. Still here to assist you further. good luck and thanks for using FixYa.
May 16, 2010 | Asrock P4I45GV R5 Motherboard
Dear Sir I need driver sound for ASRockM266A mainboard
Here is the page to get drivers for your mainboard:
http://www.asrock.com/MB/download.asp?Model=M266A&o=All
Thanks for using Fixya.
Dec 12, 2009 | Asrock M266A Motherboard
My compaq evo d51s is not displaying on the monitor at boot up.
Cleare Bios and replace the RAm if not solved use pci vga card, cirus logic or sis 6326 AGPcard
Nov 02, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Agt error occurred
P52PM + "0*00000019(0*00000020,0*E1018148,0*0C000404)"
Jun 02, 2009 | Computers & Internet
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
UPDATING BIOS FOR ASROCK M266 A MAINBOARD
In order to update your Bios, you need to have a bootable diskette.
First make sure your 1st boot sequence is Floppy Disc. Place a bootable floppy, if you don't have one just do it by using unused floppy. Right click on 31/2 Floppy (A:), choose Format, then tick the box "Create an MS-DOS Startup Disk". Once finished use this disk to boot your system. After the system completed the boot process, replace your boot disk with your upgrade disk. Type the require command to update your bios.
Good Luck
Feb 09, 2008 | Asrock M266A Motherboard
AGP graphics card problem
first check if the card is compatable with the motherboard.
Jan 30, 2008 | Asrock M266A Motherboard
Asrock M266A Motherboard Logo
238 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
