Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
I have an Intelliflo vs3050 pump and I don't get any lights on the motor control panel at all. The circuit breaker is energized. It was working fine and one day it appears there is no longer any electricity getting to the motor control. Any ideas to try? The motor is out of warranty but has less than 100 hours on it.
  • 1 more comment
  • davea2741 Aug 28, 2010
    The expert should have considerable Intelliflo experience and understand the basic schematic of the control circuits in the intelliflo motor.
  • davea2741 Aug 29, 2010
    All voltages are nominal. Power is getting to the controller. The controller appears totally dead.
    OK, he is right. He knows a bit more about the electronics architecture. I had already come to this conclusion.
  • 12,061 Answers
I would suspect your speed controller has failed, this is a very common problem, the output SCR's/Triac's often go Open Circuit, this then will cause the exact symptoms you describe. These fail usually because of "Dirty Power Supplied"
You will have to have this Unit attended to to replace the speed controller unit onboard.
It maybe possible to remove the speed controller and simply have that repaired, as an option I guess. However it usually pays to return the unit to the manufacturer or authorised agent, for repairs, it usually in my experience, it actually gets it done, gets done faster, and works out to be the least expensive option overall.
I have your manual below for your convenience.
www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf
Posted on Aug 29, 2010
  • Pentair Master
  • 15,639 Answers
THe manual is here:
http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf
IT does not have a lot to say about the issues. The thing that you need to do is get a meter and check the voltages that are present on the system. Also you need to make sure that none of the system is on a GFCI breaker. IT might be that the controller is on one and it has blown out and the motor is not.
  • Bruce Telson Oct 07, 2012
    Poor ground make sure large green wire is connected to house breaker box. I had same problem!
  • 3,083 Answers
I would suspect that the intellitouch controller might be faulty, since it controls the voltage to the motor. This is done, as I understand, through relays, so it could also very well be a faulty relay, or slightly oxidized contacts, things of that nature. Unfortunately, I couldn't run down a schematic of the system, or any very technical information, for that matter. I would refer to your literature, and contact their support center to see if they could assist you, or if there are any known issues, etc.
Wish I had more info, but this problem wasn't reported anywhere on the net, that I could find.
Good luck, hope this helps and thanks for using FixYa.
Posted on Aug 28, 2010
Pentair Tagelus 60 sand filter- why is valve always so difficult to install?
1st why are you removing the valve so much? you might be proforming a routene task incorrectly . also when i put any valve back in i allways give it a lite coat of waterproof grease on o-rings and ball cock, this stuff can be got from any well stock hardware store in the kitchen sink section (same stuff you use on faucets) so you know it\'s food grade ,dont use car grease !!!!
May 14, 2014 | Pentair Intelliflo Vs3050 4speed Pool Pump...
Power out Failure alarm
need more info will pump motor spin freely if not turn by hand remove cover on back of motor sometimes they lock up with power off turn by hand a few times then try with power
Mar 30, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Weak return, weak suction when vacuuming
It may be the hose going from the pool to the pump intake is partially clogged. I had the same problem,, removed the hose and shoved a broom handle through it to remove tree debris.
Jul 24, 2012 | Pentair Intelliflo Vs3050 4speed Pool Pump...
Will my vs3050 intelliflo pump communicate with my intellitouch i9+3s system that was made in 2005?
To make these units communicate, you would need to purchase additional equipment.
The IntelliComm will provide the communications bridge needed to operate this equipment with your existing model. Below is the manual for intellicomm and it has detailed instructions on how to connect this device to the intellitouch using various different methods.
http://www.pentairpool.com/pdfs/IntelliComCommunicationCenterIG.pdf
Apr 11, 2011 | Pentair IntelliFlo VS 3050 High...
Motor will not come on everyday. comes on some days and then others, you have to start it manually. Replaced control panel 6 weeks ago and worked fine, now same problem again. Motor runs at lowest speed...
FIRST: When you shut the breaker off and then back on was it because the breaker was "tripped" ?
SECOND: Does the motor run "hot"? Feel the outside of the motor casing when its running to check. ****becareful - it may be really hot****
As soon as you get back to me with the information I can tell you what is going on and what direction to go in. Thank's
Dec 08, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I want to know the components required to make 6HP load pump pane
You havent indicated what voltage of phase. Is it single phase or 3 phase. 120V or 480V? Bacically you need some type of fuseable disconnect (breaker or fuses) a motor starter (contactor with overloads) and something to control the starter (either manual starter or coil energized starter controlled remotly. A good source of info is: www. Mikeholt.com
May 25, 2010 | Electrical Supplies
Bathtub pump totally dead, pump ran dry for 10 sec, is there circuit breakers on pump motors, switch or is it the motor shot. any way to test motor with removing it?
Normally pump motors are connected on a separate
circuit with its own circuit breaker. At your house there is always a electrical control panel housing several circuit breakers for lights, power outlets, range, aircon, motors, etc...Find a tripped off breaker and reset it. To reset the circuit breaker is to switch it to off position and back to on position. Better still you may reset all the circuit breakers except the main
circuit breaker (biggest amp rating).
After resetting the circuit breakers, try to switch your
bathtub pump on, (to test it, if it is still okey). Other-
wise, your motor is damaged and you got to have the
motor rewinded, to be operational.
Dec 09, 2009 | Plumbing
On light does not glow and can not "stop" the system
the rain shouldn't have hurt the control panel. it sound more like damage due to lightning.
Jun 07, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
497 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
