Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
I need to know what kind of oil do I use to change the oil in my skill saw 77? Mine is pretty dirty, runs great but thought I should change the oil. Thanks Bill
Use Skil worm drive oil #80111 ($5-$6.00) at Home depot, or Bosch WD7LUB 2.3 FL. OZ. (I bought for $3.50 at Bosch service center.)
Posted on Sep 04, 2010
Olds aurora 95 ac -- freon good. starts good in am. runs great. ac blows ice cold 60 degrees ( using a lazer temp gauge) out side temp 77 degrees -- ran for 2 hrs. ice cold. Then outside temp over 85...
About the only thing that it could be is a dirty coil,or some one over charge the system, I have seen just a layer of dust cause the compressor to cycle off to its thermal over load. Clean the coil.
Jul 08, 2011 | Heating & Cooling
What kind of oil do i put in my skill saw 77
This saw requires Skil's heavy-duty, worm-drive oil, part number 80111. If you can find a local vendor that has some great otherwise, type 'skil 8011' in your search engine and shop around for an 8oz tube, they can run from $5 to $10 plus shipping.
Jan 28, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need to know what level oil in my skill saw mag77 should be?
have the saw as level as possible and put in oil until it starts to run out on the bottom of thread. Make sure you use a worm drive oil, just any oil will not work properly.
Mar 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a skil mag77 saw and need to replace the gear oil skil part # 80111 ive seen sugessted that i can use an anti foaming gear oil other than skil dist. where can i get some ,grainger/ autozone?...
Basically, anti-foam gear oil is regular oil without a detergent additive. I wouldn't play around and get any oil, since your mag77 is a nice piece of equiptment, but I understand that Skill will charge a premium for their oil. If I were you I'd spend the few extra bucks to be sure I have the correct oil.
Mar 08, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How much/what type of oil goes in my old wormdrive saw?
their owners manual doesn't give an exact quantity however they say to unplug the tool first then remove the fill plug and the lower plug and the oil should run out past the first thread. they recommend using their oil 80111 8 oz. tube however any good worm drive lubricant will work, Don't use anything like gear lube because the worm drive lube has an additive for anto foaming. Let me know if you need more assistance
Nov 18, 2009 | Saws
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Describe your Skil 7 1/4" Magnesium
You have large plastic screw on the saw, remove it and fill the oil to bottom of threads and that should be it.
Sep 15, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know how much oil goes into a skilsaw worm drive resvr.
Haven't heard anything so I checked the Milwaukee worm drive saw and they recomment about 1/2 oz. Make sure you use an oil for a worm drive that is not foaming. Hope this helps. Also when checking oir level have the shoe set for max depth and on a flat surface remove the oil plug, when filling tip the saw on its side and fill, turn back over and allow excess oil to run out if overfilled.
Jan 20, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
592 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
