posted by RonaldGwapo on May 07, 2008
my computer cannot detect my external usb 2.0 hdd it happens when it accidentally dropped.
Best Solution
posted on May 08, 2008
If you would like to bring/send it to us we will give you a free quote on data recovery. Don't know where you are but we charge less than half the price of other recovery companies.
www.dorchestercomputerrepairs.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 11, 2008
If you are able to get into your external drive
then remove the existing hard drive and add it as a slave inside your pc.
You may have just damaged the internal connections of the casing for the
external hard drive. If that doesn't work, then consider data recovery as
in your first response.
Dale
Dale
Solution #3
posted on May 17, 2008
hi I Know your Problem see hear
check your U.S.B Cable and usb port ok and what os your using xp or 98 tel me first - reinstall usb 2.0 drivers ok enable usb port see below
go to control panel - system - Hardware - check drivers for usb ok i f any Probalm 919849073383 by
Solution #4
posted on May 09, 2008
If u know how to get inside encloser, carefully check to see if any wires coming from USB connector to chassie (inside) are "torned", pulled from socket conector. If u want to try something?
turn computer on, after the "dust" settles [screen on, program on, etc.] plug in h/d into usb. Wait to see if cpu see it. If not, turn h/d on one side and TAP!! lightly, on a hard serface with a soft lining , keep taping lightly.... and reboot computer. Try this on EVERY side of h/d. u may get the " heads " to align with the plantn (mispelled?) you know the spinning things that hold the information on the h/d.
IF it works, BACK UP !! your programs on onother h/d P R A N T O !!
Suggest a new solution for this problem
Post a New problem for ASUS A7S333 Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Repair Service
Find Motherboard Repairman Near You:
