Samsung SQ 3000 manual - Office Equipment & Supplies
How much would it cost me to rent a 3000 sq ft office at $16 per sq ft per month?
Patricia, 3000 x 16 = $48000.00 (I assume this is per year.)
$48000/12= $4000.00 (a month)
Verify with owner of property.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 04, 2016 | Heating & Cooling
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
What are the settings for 5 lbs. 1000 sq ft on a scott speady green 2000
the low end od the stting bar is for 1/2 pound per thousand sq ft each mark adds 1/2 pound
Sep 24, 2011 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Scotts EdgeGuard DLX I want to apply ferti;izer at a 6# per 100 sq ft rate. What number setting would this be
If the proudct you are planning to apply has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can use that recommendation in your Scotts EdgeGuard DLX. If they do not have a suggested spreader setting for the SpeedyGreen or SpeedyGreen 3000, then this question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further.
May 13, 2011 | Garden
Is this product ideal for 3000 sq ft. basement
Yes... it should work just fine for you.
heatman101
Apr 16, 2011 | DeLonghi DE500P Dehumidifier
I need spreader setting to do 2.3 pounds per 1000 sq ft
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
Feb 17, 2011 | Scotts Company Scotts Lawns Edgeguard...
Need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
No Manual
Here is a link for the user manual for your camera. Hope this helps.
http://www.nikonusa.com/pdf/manuals/coolpix/CPSQman.pdf
Feb 03, 2008 | Nikon Coolpix SQ Digital Camera
204 people viewed this question
jasbo
jasbo
