Question about AEG Washing Machines
AEG Lavamat 64810. No error codes displayed. Drum does not spin. No motor noises. Control panel seems to work normally albeit wash cycles are accelerated with no drum action. Takes and drains water ok. Pump working. Door locks and unlocks ok. Tried to reset by disconnecting power for awhile. No joy.
  • AEG Master
  • 17,129 Answers
The fault has been described well by you and it is confirmed that the motor is not running. Now eventhough you have mentioned a clean chit to the control panel I would like you to take a voltage check on the motor when it is in wash cycle.
If the power comes on and there is no motor action then it is confirmed that the motor is fauly. But if there is no output of the voltage to the motor from the controller, the it is possible that the controller is faulty.
If motor is humming and is of single phase type, check the capacitor and replace if motor is humming and not running.
.I am sure you can sort this out having come this far.
Hope my tip helps
Posted on Aug 28, 2010
I have an AEG Lavamat 74810 washing machine which is 10 years old. On any cycle , the drum does not spin, on pressing the two left hand buttons, you get error code E52.
The E52 code indicates that the motor is not moving. This could mean the the carbon brushes have worn out, the entire motor is bad or that the wiring or control units have damage so that the message to spin is not getting to the motor.
Take off the back of the washer (after unplugging it). Inspect the motor plug and wiring to that plug. If those look okay, take out the motor and inspect the carbon brushes. If those are worn or broken, then you need to replace them. If the brushes are okay, then the entire motor or the control board are more likely to have a fault. See http://shop.aeg.co.uk/search?prpp=20&ppn=1&psfo=A&filter=category%3ALaundry%3AWashing%2BMachines and use the full product number to find out the part numbers you may need. Other sites will have these parts.
I hope this helps. Please add the product number of your AEG Lavamat 74810 if you need assistance finding parts.
Feb 15, 2017 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Noisey AEG washing machine.
Hmm, could possibly be a relay or transformer going bad. Control panels are usually easy to remove, see if you can locate the noise. If it sounds like it is speed related to the drum turning you could have a more expensive problem related to a motor inverter if it has variable speed controls.
Apr 10, 2013 | Washing Machines
Noisy motor on AEG Lavamat model 64810 washer
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Jun 12, 2012 | AEG Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
E75 error
Looks like micro controller board problem!
Mar 30, 2010 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
254 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
