Question about Whirlpool Dryers
My dryer don't stop, it continues drying what can i do?
  • 1,531 Answers
If the happens when the door is open then you may need to replace the door switch.
also make sure to check the heating element and make sure it is not grounding out on the cabinet.
Posted on Aug 28, 2010
I have a Amana Dryer NED7200TW. At the end of any drying cycle the dryer shuts off and then turns on again continuously untill i stop it. It also shows a C and a backward C in the display. Any thoughts?
You might need a new display board (electronic timer ). Seems like the timer will not send the message for the dryer to stop when the cloths are dry
Jul 25, 2012 | Amana NED7200TW Electric Dryer
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Timer stops at 6 and dryer continues to run
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again.
Apr 21, 2009 | LG DLE2514 Electric Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dryer doesnt heat up enough to dry clothes
sound like the vent duct going thru the wall to outside is stopped up / check your duct and outside dryer flap to make sure the air is open / if blocked it will take 2-3 times as long to dry and make it seem like the dryer isn't drying / larry
Dec 02, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
