Question about Mitsubishi MSZ-A15NA Split System Air Conditioner
When we turn on one of the air conditioners, a musty odor comes out of the blower. All the other air conditioners in the house are normal
  • 70 Answers
Some times water will not drain out right need to clean the drain pan, blower wheel will also catch dirt and build up mold. The front cover should come off easy, there should be three screws on the bottom and it should pop right off after that, exposing the pan and blower wheel . Clean as needed.
Posted on Aug 28, 2010
Hi I want to ask about mitsubishi air con ducted type blinking when I set up 25 C at room temperature . Bcz our diffuser is condensation .so I set 25C. When I set up around 20 C , not blinking . Why ?
Posted on Feb 21, 2012
We seem to be getting a musty smell in the room especially as the day goes on and the weather is hotter outside. Do they make any charcoal filters? Deodorizers?
There is a deodorizing filter which (usually) comes with the unit located behind the normal filters (spongy black material). This filter is washable, however usually this odor is associated with a dirty blower wheel and/or coil. Generally speaking you should have the unit cleaned properly every 1-3 years depending on your local average humidity. This entails pulling half of the indoor unit apart and is not recommended to the inexperienced. If you do choose to attempt this on your own then you will need a basic tool set to remove the blower wheel and a good solvent (Simple Green works well as a substitute for a NaOH solution) to clean the evaporator. Make absolute certain that the main power is off before attempting anything. Additionally there are thermistors located on the coil itself and the front cover who's location is critical to proper operation, so make good note of where each part came from to ensure it goes back properly. Take your time and have fun.
Aug 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
There's a bad smell coming from my Amcor AF9000E NanMax portable AC unit. It smells like the smell that you would find in a damp, musty basement. Is there anything that I can do to illuminate this...
Yes there is. First turn the unit OFF & unplug it. The remove the air intake filter and clean it. After that, remove the water collection bucket and was it in warm water and mild dish washing liquid. Rinse and thoroughly dry. Doing this should help to eliminate the odor.
Thanks for choosing FixYa.
Jul 29, 2011 | Amcor AF9000E Portable Air Conditioner
Our mitsubishi split system heat pump MSZ-A 12NA is emitting an odor - swamp water smell.
Usually if you get a musty smell, the unit is short cycling. This means the compressor is coming on, then turning off for a couple minutes, then coming back on. The best way to tell if this is the issue is to turn the unit way down stand outside and see if the compressor is turning on and off. If it's staying on, let me know and we will go from there.
Sep 28, 2010 | Mitsubishi Heating & Cooling
My dehumidifier will not stop running coils frost up musty odor from it
there is a freeze stat on the unit it connects to the evaporater coils it is suppose to shut of the compressor unit when it senses the temp is at freezing the idea is that the unit condenses moisture out of the air like your air conditioner for your house or car this part is dirty or malfunctionong
May 01, 2010 | Kenmore 53509 Dehumidifier
Ac works but when cut it off blower comtinues to work inside house-will cut off with the braker switch on it but turn it back on and it comes on even when air is set on off. Please HELPPPPPPPP!
You have a bad fan booard or fan relay. Get service tech to change. Some things you cant do yourself. To many fan boards are out there. Fan relays are pretty common. Goodman units have a fan sequencer. Carrier Brynats and and others have fan boards. get a quote befor you commit. That way you know how much it will cost. Rus
Jun 26, 2009 | Weather King 10AJA3601AH Air Conditioner
Dirt blowing out vents and has a bad (musty) odor
If you live in a dusty area it is a good idea to use the recirc button on your a/c control head. This will keep the dust to a minimum.
To get rid of the smell you can take a bottle of air freshener and spray it in the heater box air intake that is located just below the windshield on the right hand side of the van. Do this with the a/c on and blowers on high.
If you use recirc as much as possible the dust should slowly work it way out of the system.
If these fixes don't help the dash will have to be removed and a/c evaporator will have to be cleaned or replaced.
Aug 15, 2008 | 1997 Dodge Caravan
Mitsubishi MSZ-A15NA Split System Air Conditioner Logo
355 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
