Question about Samsung SyncMaster 214T 21.3" LCD Monitor
How do you open up a Samsung 214T
Hello... Can anyone please tell me how to open a Samsung 214T as I need to fix it. The screen is very faint so I assume it is the backlighting. Any ideas? Many thanks.. David.
You have to pry it open with a small flathead screwdriver.
Almost all of them are invisible, so jab your screwdriver in there and pry it sideways until you hear a pop.
You will not be ableto do this without some plastic being deformed.
Posted on Jun 02, 2008
Samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Jun 07, 2012 | Samsung 215TW SyncMaster 21" LCD Monitor
Hi, my samsung syncmaster 214T starts up and flickers hard permanently. I can do everything, change resolution,refresh rate and the monitor responds but it does not stop flickering. Is it a power supply...
Flashing or flickering is a common indication of failing capacitors in the power supply board. The fix is very simple and just requires replacing 5 capacitors on the board. They will need to be soldered. Here is a link to a repair guide for the Samsung 214T units. http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jul 03, 2011 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 214T wakes up from hybernation flickering (Windows 7)
A flickering display usually indicated a failing power supply. Check out our web site at www.ccl-la.com We have a free step by step repair guide for the 214t that will show you how to open the case. Once inside look at the power supply for parts called capacitors. The tops should be perfectly flat and I would bet your have bulges which indicate they are damaged. If you find bad caps and them replace them you should be back going without any flickering. Many LCD monitors will have issues after 2-3 years of use. If you have any more questions just let us know.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 19, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
3 year old Samsung 214T Monitor not workihg
Seems to be a problem with power supply or the Invertor board.You need to open it to be able to fix it.
Samir
Jan 03, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3 conductors
Leaking capacitors on power supply in monitor atleast replace the 2 820u & 1 330u 25v
Look for electrolite ozzing out
Aug 25, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T flickers
Hi There,
I managed to fix my Samsung SyncMaster 214T from that flickering. Just changed 3 capacitors and it worked fine!!
Jun 01, 2008 | Samsung SyncMaster 214T (Silver) Monitor
Syncmaster 214T
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
May 15, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
SyncMaster 214T Flicker Repair
We have a step by step repair guide posted on our web site at: www.ccl-la.com. The guide shows how to dis-assembly the monitor and what needs to be replaced.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 07, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Resolution message
Right click on your desktop and choose properties. Click on the settings for your problem monitor and you should find the option to change the screen resolution.
Feb 28, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
214T - flickers radidly
Yes,
A flickering screen indicates the power supply is not properly filtering the output power. This happens when the capacitors on the power board start failing. Here is a link to a repair guide that shows how to dis-assemble the unit and what to look for and replace on the power supply board. The repair guide also has videos showing the process.
I hope this helps, if so please rate my solution.
BuddyMc
May 02, 2007 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
324 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
