Question about LG Refrigerators
Icemaker no longer working at all on LG Model LSC27950ST. Any suggestions??
  • 1,531 Answers
Check and make sure the fill tube is not blocked with frozen water.
Make sure the water supply valve is good.there is a chance that you need to replace your ice maker or your main control board
Posted on Aug 28, 2010
How do I put my LG side by side refrigerator LSC27950ST in test mode? It is beeping every 30 seconds and the door is not open.
Theres a button to shut off door alarm. check to make sure doors are shut. if that doesnt work , is there any error codes showing?
Jan 25, 2017 | LG Refrigerators
Ice Maker No Longer Working
The icemaker contains an electric motor. You might have drowned it.
Nov 13, 2013 | Kenmore Refrigerators
Lg ice maker overflow
The ice tray warps after so many years and is no longer level. Replace ice tray for $3.05 from RepairClinic.com Item #1266779 ...From what I can see this Item is the same for for all LSC #######TT refrig.icemakers. Another solution I found was to adjust the flow amount into the tray. The only screw that might have worked for this did not turn.
May 11, 2012 | LG LSC26905TT Side by Side Refrigerator
Lg side by side model number lrsc23915sw ,ice maker shut off arm only moves only about one half inch upword,front of arm attached to curved plastic piece this model was bought in canada
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
My french door with freezer at bottom ,LG icemaker making very little ice.
Perhaps there is not enough water coming into the tray on each cycle? Are the ice-cubes very thin? If so timer needs to be reset. LG use a 3-switch DIP on a control panel near the main power board. By changing these switches to various combinations of on/off you can change the timing - longer means more water each time (but too much water means overflow into the blocks already made).
There are service manuals that explain what each setting does - but because its near the high-voltage power board, I'd suggest you get a repairman unless you are a good DIY'er
May 12, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG refrigerator LSC27950st touch panel
LSC27950ST Ice dispenser works fine, unable to dispense ice cubes or crushed. motor works great with no load. just doesn't seem to have enough power.
Apr 01, 2009 | LG LSC27950 Side by Side Refrigerator
Ice maker fails to make ice tried several times to turn switch on and off water flows to the cold water dispenser worked OK for the past several months what to do??
I hate to say this but from experience on LG icemakers if the fingers aren't turning or the if you have the flextray model the only fix is a new icemaker. Make sure the fill tube to the icemaker is not frozen also.
Oct 23, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
146 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
