Question about Panasonic Televison & Video
I have a NV-FJ620 video - CVC is showing on the display screen and the video tape is automatically ejecting itself when I put it in.
One possible explanation is a faulty mode switch (this is a multi contact rotary swith located under the mechanical deck) which needs cleaning probably not a job for the DIY enthusiast
Posted on May 15, 2008
Error message E3 displayed
Its telling you to get real and purchase a new device.
Nov 11, 2013 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
When I put inthe video into the video it at once reject it..
Reset if exists will not help---if machine instantly ejects the tape there is a problem in the mechanism.
A look inside with top cover removed will likely reveal tape is not going all the way down or not being pulled out of the cassette and the machine will sense this and kick the tape back out.
Most common cause for this a bad loading belt or something in the mechanism that is not moving.
It can be a do it your self fix if a belt etc.
Dec 19, 2012 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic NV-Fj620 What's youThe turns it self off a few seconds after being swithched on. Display shows F 04. Please advise what the fault is.r problem?
This deck uses the K-Mechanism. Which you can find information by searching the web for it. F04 means the mechaism is locking up whilst it's unloading. The solution is to look at the Load Motor and the timing of the drive to it.
Dec 15, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a NV HD 630 panasonic on the display appaers "CVC" and it doesn't work anymore... The meaning of CVC is not explained in the guideline
CVC is not a fault indication, it's actually the video trying to play your tape at the best quality. I think it stands for Crystal Vision Clarity, or something like that. Without knowing what's happening (IE what you see on the screen) I can't help futher. Though I would suggest you try a cleaning tape, as that can clear up many loss of picture problems, if that is what is happening to yours.
Sep 29, 2010 | Panasonic Televison & Video
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Philips video
time to have its belts replaced
Oct 11, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
