Its a ruud air conditioning unit manafacture year is 1989. It won't come on at all. unit has power
  • 70 Answers
Do you have control voltage? Check fuses and the transformer, mabey a sftey switch?
Posted on Aug 28, 2010
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
My mother had a ruud furnace/air conditioning system installed 8/2003 - the installer now says the condenser is gone. She died in 2/2010 so the system was used only 9 years. Do condensers go that quickly...
Hello
Usually there is a 1 year warranty from the installer and a 5 year from the manufacturer.
It may not be the Whole condenser is bad.But the compressor in the condenser is bad.Ask your repairman about that.R22 units are getting hard to get now as they will soon be gone.
9 yrs is a little short but it depends on how often it was used and maintained.
You certinly can try Rudd and see if they will do something.
I doubt they will. I know lennox does not.
Jul 21, 2011 | Ruud UAMB030 Air Conditioner
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
I am trying to find a parts list for a RUUD UAKA-030JAZ air conditioning unit (specifically the compressor/condensor contactor).
RUUD will only sell there factory parts to certified contractors. My advice to you is to find a local HVAC parts distibutor that will sell you generaric parts which will work just as good as the factory parts.
Jun 23, 2010 | Ruud UAKA030 Air Conditioner
Ruud air condition
You must be kidding. You want a video?
If the filter is in the air handler, it is in the bottom. Often filters are not in the units themselves, but in the main return grill in the ceiling. But if it is in the unit then:
Turn the unit off at the thermostat. (That way the fan is not sucking the filter up,) Then take the bottom door off. It is a small door and a pain, but you can do it. Pull out the filter. It is a washable black plastic framed thing. Then wash it and put it back in. Then make sure to put the door back on and turn the thermostat back on.
Jun 14, 2010 | Ruud UAPA024 Air Conditioner
I have lost my remot controlfor my air conditioning unit model number MCFH-24NV and year of manafacture 1999-01
Attached is a link to the Mitsubishi site. Choose your location to contact their customer support. They can help you find a replacement remote control.
Let us know if you found this helpful and Good Luck! :-)
http://global.mitsubishielectric.com/company/corp/offices/index.html
Feb 21, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Its a ruud air conditioning unit manafacture year is 1990. It won't come on at all.
if you dont know what you are doing it is best to call a professional. you could damage the equipment or get yourself electrocuted.ask your neighbors who they use.It could be a simple problem or major,hard to say without looking at the unit.Most common problems are simple repairs such as blown fuses,bad contactors/capacitors and are not that costly.
Aug 09, 2009 | Ruud UBHC Air Conditioner
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
