Question about Kenmore Kitchen Ranges
The glow ignitor for bake does not glow when I turn the oven on to bake. Therefore the bake burner does not turn and and flow gas. But when I turn the oven on to broil the broiler glow ignitor comes on and glows and also the burner turns on and gas flows.
  • 4,323 Answers
Hi
To resolve the issue you’ll need to check the glow bar, measure the current on the igniter. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, its resistance increases to the point where not enough current is flowing to the gas valve bi-metal to open it up. As a result, the gas valve never opens up.
The hot surface igniter will not come on then check the igniter with a multimeter, you should have continuity through the glow bar, and the glow bar can also break. The glow bar comes on but the main burner will not light, but often this is a hot surface igniter problem. The hot surface igniter often loses its ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking, it means that it may work sometimes but not on other occasions. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas without the oven working. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 28, 2010
My gas oven (Frigidaire Gallery) is not preheating or coming up to temperature. The broiler and stove top burners work fine.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
Jul 18, 2011 | Frigidaire Ovens
My husbad had sent out an email of our problem that we are having with our range. I am not seeing that there was a response. Is it possible for someone to assist us? I turn on my oven but it does not heat...
Hello Kim....Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective. That said, if you want to see excellent diagrams of all of the parts of your stove, go to searspartsdirect.com Enter the model number and these diagrams will appear for your use. You can also order parts from that site, although your local appliance parts store may be less expensive. Joe Thanks for choosing Fixya!
Jan 13, 2011 | Amana AGDS902 Gas Kitchen Range
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    I have a Whirlpool Super Capacity 465 oven Model# SF315PEG. The bake valve was being energized but not opening to allow gas into the burner. Bought a new valve assembly P/N 3195008 and replaced. Problem...
    The ignitor is not allowing enough 'current flow' to open the valve. The ignitor , even if it glows, can be 'low current' to valve.
    (the ignitor current controls valve)
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
    Sep 03, 2009 | Ovens
    Oven won't light, even with ignitor getting red
    If your oven won't bake, check these:
    Bake igniter
    Other causes
    Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
    Other causes Other reasons that your oven may not bake are:
    • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
    • The thermostat is defective.
    • The safety valve that prevents accidental gas flow is defective.
    • The selector switch is defective.
    May 23, 2009 | Magic Chef 9122 Gas Single Oven
    Oven will not light but smell gas
    i think you probably have a weak ignitor. does the ignitor glow orange?
    if it does, or i should say when it does, just tap lightly on the gas valve and see if that causes the gas to flow into the burner and then light.
    you can use the handle of a screwdriver to tap with and it wont need to much force.
    if this does work, then just replace the ignitor. when they get weak they will glow, but wont draw enough current thru the gas valve to allow it to open. your valve does get voltage but it opens when enough current draw opens the bi-metal portion of the valve to allow gas to flow.
    Jan 12, 2009 | Tappan TGF320 Gas Kitchen Range
    Kenmore Oven
    Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
    Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
    rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
    Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
    PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
    Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
    Gas stove
    The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
    Sep 04, 2008 | GE JGRP17 Gas Single Oven
    Bosch HGS442UC Gas Oven won't light
    if this helps please vote me a fix ya
    Jul 18, 2008 | Bosch HGS442UC Gas Kitchen Range
    Kitchen Ranges Logo
    177 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Sal De
    Justin Duby
    Justin Duby
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
