Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Diamo velux 05 scooter wont start troubleshooting
Cranks but wont start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.linnbenton.edu/auto/perform/no_start.html
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
http://www.carlsalter.com/diamo-service-manuals.asp
Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
Mar 19, 2014 | Diamo Cruiser Motorcycles
Diamo scooter kick starts electric starter not wiring
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Scooter Troubleshooting Scooter won start All about Scooters
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial http://scmotorized.com/image/data/pdf/scooter-repair-manuals/Retro-150--Parts-Catalog-V.12.07.pdf
Diamo Retro 150 2007
Sep 24, 2013 | 2007 Diamo Retro 150
DIAMO VELOCITY 50 IS SLUGGISH
Hi, Reggert for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.scootertherapy.com/runslowpage.html
Slow scooter
Oct 02, 2012 | 2008 Diamo Velocity 50
Where can I find a 2009 diamo Velocity 150cc scooter manual
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Derbi despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Diamo Velocity 150 2011
Tips Tricks
Sep 12, 2012 | Diamo GTS 125 Super Motorcycles
Tips Tricks
2009 diamo velocity 50cc spark plug gap
Hi, Integrattype 8 mm or .032" sorry you can't find the first and best tool you ever bought for your Derbi despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Archived Scooter Repair Questions Engines Starters
Spark plug gap in English please Scooter Doc Forum
Aug 17, 2012 | 2009 Diamo Velocity 50
Diamo 200cc no fire
Hi, Corey and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
What to do When Your Motorcycle Won Start
troubleshoot motorcycle not starting
http://www.carlsalter.com/diamo-service-manuals.asp Scooter Parts for Chinese Scooters Atvs
Apr 29, 2012 | 2009 Diamo LS 200
I need a wiring diagram for a 300cc Diamo Turista scooter made by Linhai
Hi, Terryneal086 sorry you can't find the first and best tool you ever bought for your Derbi despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.jr-richscooterdoc.com/Help_electrical_explained.pdf Diamo Turista 300 2008
Jun 10, 2011 | Diamo GTBO 70 Motorcycles
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
87 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
