Question about Vector Vec143 Bright Bar Work Light
Will not charge, measured output of charger and found no output. want to try other chargers but not sure if the bare post is + or -. Can you help.
  • 28 Answers
Take the charger to your local electronics store and they can help you find one that will work.
Posted on Aug 31, 2010
My makita battery is not taking a charge is it the base or the battery
The most easiest way to be sure is using multimeter. 25290419-3h5pkc2unruv115jj1tsixdi-2-0.jpg
Set your multimeter to highest dc volt. All chargers have output voltage information written on it (Must be written as "output" value or "sec"). Measure charger's output pins (which connects to battery) and be sure measured value matches with output voltage value written on charger label. If it doesn't match each other, buy a new charger and proceed with below part.
Discharge your battery. Once you discharge battery; be sure that there is no charge at all. Charge battery for 15 min. Measure battery power with multimeter again. If there is no charge at your battery, it is dead and you need another battery.
Nov 19, 2014 | Makita Drills
Invacare battery charger 24 volts no output if not connected to battery?
If the battery has stood for two years with out a charge it will no longer be able to hold a charge renew it . most modern chargers need to detect battery voltage before they will charge .
Sep 17, 2014 | Health & Beauty
Finepix jx400 won't charge
Did you charge the battery on the BC-45C charger? hat should be the best way to charge your battery. It should be fully charged within 2 hours. To make sure your battery still has its capacity you can measure the output voltage. On the battery is printed 3,7 Volt. With a multi meter you should measure at least 3,9 Volt, because the multi meter does not ask any significant current. if it is under the 3,7 volt you can be sure the battery does not have enough capacity to let your camera work correct. The charger will deliver abut 4,2 Volt.
Jan 04, 2014 | Cameras
Wont charge or turn on
1) you must sure about if the charger is o.k , measure the output charge and compare witht the label attached, if the voltage label is NOT the same, the charger is faulty.
However clean with solvent spray for contacts, for dust, oxide, corrosion.
Merry Christmas
Dec 20, 2013 | Samsung PL 70 SL720 Digital Camera
I got a 7" mini
1.make sure that the charger is the same.
2.if it's the same then you need to replace the battery.
3.our can cross check your charger with your friends 7"min if he has one !!!
happy computing !!!
Jun 18, 2011 | Computers & Internet
Hello, i have a invacare wheelchair that has 2 12v sealed batteries, wired in series at 24v. I wanted to find out the charge plug has 3 prongs, which should be -. ground, . over vice versa, how come there...
Salty The charger detects the batteries when it is plugged into the charger port. With the older chargers you could measure the output of the charger by measuring across the two outter pins. With the newer chargers there is no output until the charger is plugged into the charger port. Now on the M51 you should have an on-board charger and the cord plugs into the back of the chair into a three pronged plug. Now if you plug the on-board charger into the wall socket and look at the rear of the chair low to the ground you should be able to see a red and yellow light (red and green when fully charged). With this charger plugged in you can take a digital voltmeter set it on 200 v dc and plug the leads into the two outter holes in the charger port under the front of the joystick you should read 27-30 volts when charging and 24-27 volts fully charged and the charger unplugged. Hope this helps you
Sep 20, 2010 | Invacare Pronto M51 Power Wheelchair
Battery dies after a few minutes
Is this a toy? Is this equipped with deep cell batteries? Checked the water? Check the voltage of each battery in the pack ... should be 6 volts each ... charger putting out? Check while charging ... should be 25+ volts (make sure you measure DC.
If you have a battery that is particularly low ... it will have to be charged independently ... If this is the case, with a 6 volt charger - charge that battery. If you have two batteries that measure low ... you can charge with a 12 volt battery. You will not have to disconnect anaything to do this ... just watch what you are doing ... do not use the unit charger AND the 6 or 12 volt charger at the same time.
May 02, 2010 | Polaris 800 Twin Sportsman Ride on Toy
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
Vector Vec143 Bright Bar Work Light Logo
107 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Jim London
Jim London
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
