Question about Dishwashers
My dishwasher wont drain the water , I have had a plumber check the pipe that it drains from and their may be a blockage - any suggestions to clear it
    Genius:
  • 1,073 Answers
Replace the drain drian line if there is a blockage
Posted on May 08, 2008
DRAIN PIPE CLOGGED
hi Calculas.
A few different methods can clear the drain pipe of debris and get it back to draining water the way it was designed to.
  • Locate your drain behind or under the washing machine and detach the tubing or pipe to access the actual drain. ...
  • Clean out any blockage inside the pipe with a plumber's snake
  • try this link for more info on this matter.
How to Fix Clogged Laundry Drain
Dec 12, 2017 | Washing Machines
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
Fixya login
Unfortunately this sounds like more than a blockage. If this was a blockage water would not drain, maybe fill in sink or dishwasher etc. If water is coming from walls probably means it is leaking from drain pipe in the wall. Which would mean opening wall to find leak.
Aug 14, 2013 | Mountain Plumbing Plumbing
DISHWASHER WILL NOT DRAIN PLUMBER WAS CONTACTED DRAIN LINE IS FINE LOOKING FOR OTHER CAUSES? THANKS, SEAN
Can you hear the pump trying to drain it? If you can then you have a blockage. Try blowing hard down the outlet hose, what happens? Have you checked all filters?
Mar 06, 2011 | Frigidaire FDB1502RGS Built-in Dishwasher
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher is draining through the vent cap at the top back side of my sink ??????
Sounds like you have a blockage in your drain pipe. run a plumbing snake down the drain and see if you can clear it, otherwise, i'd be looking for a plumber
Apr 02, 2010 | Frigidaire 24 in. FDB1250RE Built-in...
Dishwasher not draining (neff slimline intergrated)
I had this problem and eventually after trying everything short of pulling the dishwasher out and checking the hoses I tried Finish Dishwasher Cleaner. Much to my surprise, IT WORKED.
Dec 30, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher does not drain
My dishwasher will not drain. The water stays in the bottom of the dishwasher. When it should drain, I do not hear anything happening where I used to hear the pump working. Is my pump bad?
Jan 10, 2008 | GE 24 in. Profile PDW7880G Built-in...
Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Sep 23, 2007 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
