Question about Pioneer VSX-D511 Receiver
I have a Pioneer vsx-d511 connected to a powered subwoofer (Tannoy Mercury) via the preamp subwoofer connector. This gives to much power to the sub, even with all settings correct. Any ideas?
Try turning down the sub woofer output volume and/or alter the sub woofer crossover point to a lower setting, try 100 Hz, - Rod
Posted on Oct 04, 2010
I have a Pioneer VSX-1123-k receiver and a Klipsch SW 450 subwoofer and the connection is not clear. Can anyone help?
Should be an rca connector on the back of the receiver marked subwoofer or sub preout. connect that to the rca connector on the sub and it should be good to go.
Sep 26, 2013 | Pioneer Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
How do i connect a subwoofer to my vsx-9700s
on the back of the pioneer, you have a subwoofer preamp output jack, probably colored black, as opposed to red or white. stretch a rca cord between there and the red and white (or lfe) input of the sub. youll then have to check the amp setup menu and make sure it has the output activated. good luck
Feb 11, 2010 | Audio Players & Recorders
JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
Feb 20, 2009 | Pioneer VSX-D511 Receiver
Trying to connect powered subwoofer
Try setting the speaker settings on the receiver to small.
Jan 12, 2009 | Pioneer VSX-D511 Receiver
Sub not working
The sub pre out is for a small output signal which is to send a signal to a power amplifier which amplifies this signal to a level that will drive the subwoofer. the preamp out signal is not capable of driving a speaker without being amplified.
Aug 17, 2017 | Pioneer VSX-D514 Receiver
Sub woofer
Is there a gain control on the sub? If not, are you using a receiver or pre/processor to control volume? There could be a level adjust or on/off control for the subwoofer output.
Jan 20, 2008 | Pioneer VSX-D511 Receiver
Woofer problem
If I am not mistaking here, you need a self powered subwoofer to use with this unit. Those are line driven outputs for this unit. Make sure there is a wall plug on the sub that is plugged in. Good Luck
Jun 07, 2007 | Pioneer VSX-516-K/S Amplifier
Pioneer VSX-D511 Receiver Logo
246 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
