Question about Electrical Supplies
Gas leaking on plate between air filter and carb on my Homelite LR4400
  • Robert
    Robert Sep 01, 2010
    please what is the mod# as well as the ser# of the unit
  • 90 Answers
Your carberator float may be stuck causing the bowl to overflow.
Posted on Sep 01, 2010
My leafblower won't draw fuel, despite a new carburator. If I put a bit of fuel in the cylinder, it turns over easily for a second or two, then dies.
Who put in a new carb? Ask them. Check for air leak in fuel line or clogged filter at intake inside gas tank. Maybe intake tube is not down in the gas tank far enough.
Jul 05, 2014 | Homelite Mighty Lite Blowervac
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
Mar 20, 2013 | Homelite Garden
Weedwacker won't stay running
replace the fuel lines and check that the filter in the fuel tank( its on the end of the intake fuel hose) is clean. If there is an air leak somewhere in the old lines it will cause the trimmer not to get enough gas.Then clean the carburetor with carb cleaner- take the carb off by removing the air filter first then undo the two nuts holding on the carb and take off accelerator cable remembering which hole it came from. spray the hole carb with the cleaner on the inside and outside then soak it in the cleaner trying to get any dirt out. put it back together and it should start...if not you might need a new diaphragm in the carb.
Jun 20, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite 16" 33cc chainsaw. Sarts but win't keep
Hello rick.... Get an aerosol can of starter fluid at your local autoparts store. Also get an assistant. Remove the air filter and start it up. Have your helper squirt some starter fluid into the air intake to keep it running for a couple minutes until the partial blockage in the carburater clears. Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Homelite Garden
Stihl gas trimmer bogs out, everything else is fine
check air filter if clean check spark arresterin muffler usually a screen under plate where exhaust comes out also tube shaped can be pulled out with pliers,if clogged canclean with wire wheel also can remove muffler tosee if exhaust port ic clogged with carbon if all is ok problem maybe with carb hope this helps
Aug 13, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite model uto8550 26cc mighty blower/vac. On initial startup it runs at half choke then stalls when i turn it to run. Any suggestions?
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
Oct 23, 2009 | Homelite Consumer Products MightyLite...
Gas floods out engine,if I pinch the line (regulate the flow) I can get saw to run.XL360 homelite
I sounds like there is some dirt under the needle valve in the carb. Change the fuel filter first, if it is falling apart then it is very likely a piece of it got in the carb. Try spraying some carb cleaner directly into the fuel inlet to see if you can flush it out first, If not then your going to have to pull the side closest to where the gas goes in off the carb take out the little screw and clean under the needle valve.
Mar 19, 2009 | Homelite Garden
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite hb 180 leaf blower
Changed all major gaskets: Cylinder to crankcase, case half, exhaust & carb. Now it runns right. The carb can be adjusted and the choke is full open when warmed up as it's supposed to be.
Gaskets ca be bought from Homelite directly at http://www.homelite.com/service_support/order_parts
Enter the model numbers & see the exploded views. Torque values are provided in the parts lists.
Nov 01, 2008 | Garden
Electrical Supplies Logo
169 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
