Question about Sony SLV-660HF VHS VCR
Need help with the Sony SLV-660HF VHS VCR. I had an error code of E30105, followed by error code E31805. The tape currently in the vcr is stuck and it will not respond to eject or do anything but turn on and off. It makes a whirling sound every time the eject button is pressed, though the tape will not remove itself. One site recommended using an alignment diagram, but there seems no way to find them. Please help.
2 Suggested Answers
SOURCE: Sony SLV-660HF VHS VCR I had an error code of
Don't have a solution but I have exactly the same problem. Pls let me know if you figure it out.
Posted on Dec 30, 2010
Will I be able to convert from VHS format to DVD using the SLV-660HF assuming I have the converter cable and software?
Don't see why not. Search E-Buyer.Com for something called Videomate C100 Video Audio Capture Card, that will set you on the right track to record on to DVD, software included to make DVD's.
Aug 19, 2011 | Sony SLV-660HF VHS VCR
My tape was stuck in the unit, managed to free it up and noe I have an erro code of E3 on the LED screen, what does this mean?
First you must make sure you got all of the video tape out of the unit. Unplug your unit from power and check for any remaining tape. Any small piece of tape could jam your unit and give you error code E3. Once you know you removed all tape leave your unit unplugged for 5 minutes to see if it clears up the error code. E3 is a drum rotation error code and usually clears after plugging the unit back into the power. If this did not help then further repair will be necessary.
I hope this helped you out! Good Luck!
Nov 15, 2009 | Sony SLV-660HF VHS VCR
Sony SlV-SE730 VCR video inserted wrong way
Unplug the VCR.
Take the cover off by taking out the small screws on the sides and on the back that hold the cover on.
With the cover off you should be able to gently move the tape back out.
Things could be damaged......after the tape is out, you should try it first with a tape that could possibly be damaged during testing and do not touch anything inside while plugged in to power during testing with the cover off!
Now......if it is not a working VCR anymore......you are in luck.
There are garage sales every weekend...and almost every one has a VCR for almost nothing....some like new.....and boxes and boxes of tapes/movies for very little money too.
Sep 06, 2009 | Sony SLV-SE730 VHS VCR
SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Jul 11, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Mitsubishi galant cd player
Battery in the remote? What is your model number?
Dec 19, 2007 | Sony SLV-660HF VHS VCR
VCR Tape is stuck in Sony Video Recorder, model SLV-620HF.
In vcr you mean? try unpluging the electric cord for 1 hour
then plug it back up. it just might eject it out. mine did.
Nov 11, 2007 | Sony SLV-640HF VHS VCR
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
