Question about Kenmore HE3T Washer
I have a kenmore washer HE3T and the flash code F35 keeps coming up? Please help!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
My Kenmore Elite Front Load Washer -HE3t keeps stopping the cycle and the error F35 displays
Hi
The error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected.
Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires& 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | Kenmore HE3T Washer
My kenmore he3t washer flashes sud &code error f35...think it needs presure switch part#w10415587 how much is it?
That is a water level sensor, if it is still in warranty contact the manufacturer. If not look for the sensor and check for loose wires, if not loose wires replace the sensor.
Aug 31, 2011 | Kenmore Elite 45986 Front Load Washer
Once you start aload in few minutes SUD sign comes on after few minutes F35 code comes on. We try to clean the washer also,even after that same code is coming on .
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Feb 19, 2011 | Kenmore HE3T Washer
F36 and "suds" keeps coming on. what can i do? He3t Kenmore washer.
Are you sure you didnt read the error incorrectly?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore elite washer he3t model 110.4674 and the error code F35 keeps coming up. We did clear out the bottom drain pump, which had a lot of debris including toys, socks...etc. How can I clear the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^##
Jun 10, 2010 | Kenmore Elite HE5t Washer
I have a kenmore Elite...F35 keeps flashing..what does this mean. Please help
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(&^%#
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3t keeps flashing wash time.Won't start or cancel/pause
Mar 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3T Washer Logo
142 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
