Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Doesn;t cool at all. runs but inside temp. stays at 73
  • 1,531 Answers
Check the power at the compressor and make sure it is turning on if it is then you need to replace.the compressor
Posted on Aug 28, 2010
I have the temp set at 77 in zone 3, (have 4 zones), but temp is 73 with the ac dumping cold air in the zone. how do I fix this?
It's possible that your "slave controller" is malfunctioning. There are 4 thermostats, 1 master & 3 slave controllers(not slang but actually what they call them and I don't know why). The #3 that shows 73° actual temp, and set at 77°, is probably malfunctioning. Remove the R or Y wire inside the #3 t-stat and see if the airflow stops "dumping" in that area. Also possible that the damper controller in the duct has malfunctioned. This will take some experience to know what to do, not easy to explain.
Aug 22, 2017 | Heating & Cooling
Charging an air conditioning system
R22 systems should run a 68# to 70# suction pressue. If you look at the suction guage at 68# that is a 40 deg evaporator coil temp.
Nov 18, 2012 | Ruud Central System Air Conditioner
Cooling fan temp light stays on when air condition is on. fans are not kicking on. Is it the fan module ?
I didn't know it had a light on the dash that said "cooling fan temp".
My 93 doesn't.
The cooling fans are controlled by the computer and turned on when the ac is running or when the engine reaches 220 degrees.
A mechanic would check the fuse and relay for power and the fan motor for power and ground.
Aug 26, 2012 | Cadillac DeVille Cars & Trucks
Heat stays on even when temp is cool and compressor doesn't work
Have a professional diagnose the communication between the main control board, and the timer.
Aug 14, 2012 | Frigidaire FAH125P2T Air Conditioner
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
Cooling fans stay on
your fan will also come on when the defroster is on and when the airconditioning is on so it could be something to do with the inside temp controls
Jan 25, 2009 | 2003 Nissan Maxima
Ruud UBHC-21J18SFA blowing only "luke warm" air at best
That's crazy, we're having the same problem.  Turns out there was a wattage restrictor in the furnace that was switching off 3 of the 5 heating elements in an attempt to save energy.  Basically, the restrictor was sensing that the incoming air was warm, so only 2 of the 5 coils should be needed to heat the air.  Well that wasn't enough and we just sat with the furnace running all day long struggling to reach the 70 degree setpoint.
This is something a technician can diagnose in a few minutes, but not the sort of thing a DIY'er should really handle.
Dec 22, 2008 | Ruud UBHC Air Conditioner
Delonghi cf210 when setting temp it dosnt give any heay
just bought one.It looks like the thermostat has problem. Set at 78 F, it runs forever and the room temp is 72F. Set at 79F, it runs, room temp shows 73 F, sometimes 75F or 77F. The Ac is on then off every 5 minutes even the desired temp (is set) reached. Lousy machine.
Jul 27, 2008 | DeLonghi CF210 Portable Air Conditioner
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
