Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I have a CMM1200 19" 24 volt cordless mower that is two years old. It seems to charge just fine but when I insert the key and go to turn it on, only the blade goes around with almost no sound. The engine doesn't seem to "catch".
  • Julie King
    Julie King Apr 26, 2012
    The nut does not turn either way, but the blade spins freely. What next?
  • 10,865 Answers
Hello. It sounds like the nut holding the blade tight to the shaft is loose. With the mower unplugged and off, with the key removed, do this. lift up the mower so that you can spin the blade manually. It should not spin freely, it should be hard to spin because if the bolt is tight you would be spinning the blade and the motor. If it is loose, get a wrench that will fit the nut and then hold the blade in place with a short piece of lumber [like a 24 inch piece of 2x4] and tighten the bolt. J.
Posted on Aug 28, 2010
Can't remove the two middle bolts that hold the top on.
most likely the threads are rusted and the retainer nuts are turning in the plastic cover
you may have to take it in to a mower shop or get drastic to get it apart
Jul 23, 2016 | Black and Decker USA Black & Decker CM1836...
Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Dec 11, 2012 | Garden
I have lost the key to my 60 volt cordless Remington cordless mower. Can I hotwire the three wires going to the handle somehow?
You can do this ,but why take a chance of burning up your mower. You should be able to buy a key for this unit from your local dealer. I believe these keys are all of same cut, like a light switch. this way if you can con someone else into mowing your lawn, they can't say I'm not mechanical and don't know how to jump wires, or worst , see first sentence.I feel this will be the easier way. GOOD LUCK.
Jun 17, 2011 | Remington PowerMower 17-Inch 60-Volt...
The in line fuse between the solenoid and the ignition key blows as soon as I turn the key on. The mower is less than a year old and wiring seems fine.
Solenoid is probably shorted to ground...if you can obtain an ohmmeter..measure the resistance from the small trigger lead on the solenoid to ground(usually the mounting tab)..the reading should be around 50-200 ohms...if it is lower then the solenoid is junk
Apr 25, 2011 | Garden
No power
I think you should check the charging system. You said you replaced the battery a few weeks ago. Even with the charging system not working, the battery might have enough power for a dozen or more start-ups; but using the lights may have drained what power was left. Get or borrow a battery charger and charge your battery. If mower then seems to be working fine, measure the voltage across the battery when the mower engine is running at normal speed (not idling). It should be 13.5 volts or more if the charging system is working. 12 volts or less means it's probably not working. Either test or replace the regulator/rectifier. Please rate me if you think this helped, thanks!
May 31, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a jd 100(?) series riding mower that has
First, charge the battery.(Always do the easier things first). If that isnt the problem, take a DC volt meter and check the voltage where the battery connects to the solenoid. Then check the voltage on the starter side, while you turn the key,If there is a large voltage drop, or no voltage, replace the solenoid. If voltage okay, then check the starter. Good luck...Lee
Aug 22, 2009 | Garden
I started mower in tall grass. It started up and immediately stopped. Could not get it started. Replaced battery. Charged 12 hours. Still will not operate. Green light is on. Noticed the blade seems to...
After charging the mower, you must place the safety key in the mower before it will start. On models that have a bail handle, be sure to pull the bail handle back to the mower handle before engaging the start lever. If your mower still does not start, remove the safety key and ensure the bail and start lever are in the "off" position. Then firmly re-insert the safety key, pull the bail handle to the mower handle and engage the start lever.
Note - It is important that the bail and start lever are returned to the "off" position before inserting the safety key.
Give it try, if it still will not operate you may have to take it in for service.
Good luck, let me know.
Regards,
Jul 30, 2009 | Black & Decker 19" Electric Lawnhog...
97 Chevy Blazer - good battery, good alternator...still dies???
check battery voltage when you turn off car. it should be 12.5 volts.if drops 11.0 volts the battery is got a weak cell in it.i bought a sears die hard battery it last 2 years the battery had a defect .it had a bad cell it short out the battery.check alternator wires for defects.
May 29, 2009 | 1997 Chevrolet Blazer
Wont start
HELLO, HAVE YOU CHECKED THE SPARK PLUG,YOUR OIL LEVEL,FUEL,AND THE CABELS ON THE BATTERY TO MAKE SURE THERE TIGHT AND IF YOU HAVE A VOLT TESTER MAKE SURE ITS READING 12 VOLTS IF NOT THEN YOUR BATTRY NEEDS REPLACED OR IS'NT HOLDING A CHARGE,IS THE ENGIN SPINNING WHEN YOU TRY TO TURN IT OVER ? OR IS IT SEIZED ?ALSO IT SOUNDS LIKE IT COULD BE YOUR STARTER RELAY IF THE REST IS GOOD
Apr 06, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
122 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
