Ive just received my new TV and now my sky remote control will not work, I've been told that it has something to do with some of the new TV's that are out now. Is there a solution.
    Sergeant:
  • 247 Answers
Are you saying that your remote will not control your TV or other sources?
If it is just your TV, you need to give us the brand and the model of the TV as well as of your remote -- to see if the codes are available for your TV on this remote.
Then I may be able to help you.
Did you look them up and/or check with the manufacturer to see if they are available?
If not, you will need to buy a better (newer?) remote.
Good luck! :)
Posted on May 09, 2008
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
Feb 09, 2013 | Televison & Video
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sep 23, 2012 | Televison & Video
Sky remote control code for samsung ps43e45/49 tv
The code you are looking for is 1340. I have the same TV and my sky volume hasnt worked since I bought it, (9 months ago).. After spending an age on the SKY forum with no luck, I simply googled (Sky remote codes) and clicked on the 1st site, it's skyremotecodes.co.uk then Samsung 6000 series.... It told me the correct code and gave me clear instructions...... I hope this helps someone else.
Aug 17, 2012 | Samsung TV Remote Control
I.ve got a new tv and my volume doesnt work now on my sky remote
You need to tell your Sky Remte, what the TV is otherwise the volume control on the Sky remote will not be recognised.
Nov 09, 2010 | Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
