Question about Maytag Neptune MDE5500AY Electric Dryer
Two of my three tumblers have come out of the barrell and now my laundry will not tumble. It rolls up in a ball and rolls along the bottom of the barrell. Where can I open the dryer to replace these two tumblers?
  • 1,531 Answers
There are two clips about one inch in from either side of the machine use a flat tip screw driver and push them in to lift the lid.Then you will be able to get at the drum and replaced the drum veins,
Posted on Aug 28, 2010
Barrel tumbles and everything dries but it makes a loud noise. Lessens slightly towards end of drying cycle.
is your laundry getting rolled into one big pack? My dryer does that and it sounds like someone is stomping their feet.
Mar 18, 2015 | Kenmore Dryer Sears Elite
My daughter received an Edu Science Rock Tumbler for Christmas but has lost the instructions. Where can we request for a new set of instructions?
Wow that is a nice one you have, it is probably quieter with the plastic cover. I use to tumble my rocks either in the basement or in an empty drawer in my dresser to sort of block out some of the noise. The one I had when I was younger was probably the first do it yourself old Smithsonian rock tumbler. I'd say that was probably one of the best gifts that I have ever received.
Well, first, you put the bag of rocks that you want to tumble in the tumbler. Make sure it only fills the barrel 2/3-3/4 full or you may have to extend polishing time.
then, usually you use the thickest to the thinnest grit in that order. You put the thickest grit in first and let the rocks tumble from 7-10 days (for optimal polishing). You will do this for each grit you use.
Make sure there is no grit transferred from one step to the next. Hope this helps :)
Dec 28, 2010 | Edu-Science Toys
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from service@bhsciencetech.com
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 | Toys
Rolling Stones Rock Tumbler - no rubber ''O'' ring
Nothing high tech here. Try it without the o-ring. If the water does not start to leak out in the first 3 to 5 minutes of tumbling you will be ok. Stop it every day to check the water level.
Set the whole thing on a cookie sheet in case it does leak when you are not watching - you don't want a bunch of rock dust and polishing grit on your table or floor in the morning.
You will not damage anything by trying it without the o-ring.
Mar 18, 2010 | Rotary Thumlers Tumbler Polisher...
How do to remove ignition barrel as key broken in barrel
You must remove the steering wheel and locking plate underneath. This requires special tools that may be lended to you if you live near an Autozone and purchase the parts from them. To remove the tumble you must turn it to the "run" position with a screwdriver and poke in the small locking pin that is located on the front bottom surface of the tumbler bore. If you are unable to turn the keyswitch, it becomes necessary to replace the entire steering collar. Thank you, Dana
Feb 15, 2010 | Hyundai Accent Cars & Trucks
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Apr 09, 2009 | Dryers
Rolling into balls
There is nothing you can do about this. the disadvantage of sheets and blankets.
May 07, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore dryer
could be;
belt slipping
over loading
tumble veins inside drum broken
Dec 13, 2007 | Kenmore 62802 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
