Question about Linksys Wireless-G WRT54G Router
Forgot password for reinstalling router model #wrt54G
  • Linksys Master
  • 7,733 Answers
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP security and enter WEP key it is your password to connect wifi.Then save settings and restart router . Then when anybody try to connect your wifi it ask for that password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 28, 2010
5 Suggested Answers
  • 26 Answers
SOURCE: how to change my security password
If you forgot your password to your router you can reset it to factory settings and reset to the factory password by pressing the reset button in the back of the router for 30 seconds that would reset the ip address to 192.168.1.1 User name: (LEAVE BLANK)
and Password: admin
Here's some more information on reseting linksys routers
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=93bb017280e0407fb2322ac5d4af4166_KB4008_EN_070221_v1.xml&amsstatsid=6840304
Hope this helps you out
Posted on Jul 08, 2009
technical114
  • 1851 Answers
SOURCE: forgot my password for linksys wireless-G
You can use the reset button at the back of the router. Keep in mind that this will also reset any other configuration you have made at the router. The credentials and the ip for the router will come back to the defaults (192.168.1.1, admin, admin or none or 1234)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Dec 05, 2010
  • 172 Answers
SOURCE: forgot my password to my
If you forgot password of your router..Do not worry...
Press tiny reset button on the back of you router..It will restore all configuration to factory default mode...
the default username is admin & password is bank (no password)..
rate this if you like solution...
Thanks
Sandeep
Posted on Mar 11, 2011
SOURCE: I forgot my password for my wireless router, and can not sign my wifes new phone up on our wifi
When your phone asks for the password, out in the Encryption key. If you didn't print this out when you installed the router, insert the CD and install the Easylink Advisor, which wil then show up down in your taskbar in the bottom right corner of your screen. Open it, click on the Support tab, and it will show all your settings. For the password requested on your smartphone, enter the encryption key from your settings in EasyLink Advisor. That did it for me. Good luck!
Posted on Oct 30, 2011
Forgot password, need to reset
Most of the time on those. The username and password are
Username: WRT54G
Passoword: admin
Nov 23, 2013 | Linksys Wireless-G WRT54G Router
Security key
You can reset the router to factory defaults by using the reset button. It will not have a password anymore. After that you can choose a new password yourself. All instructions are here: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Jan 06, 2012 | Linksys Wireless-G WRT54G Router
Forgot my password to my WRT54G Router how can I find it?
Thanks
Sandeep
Mar 11, 2011 | Linksys Wireless-G WRT54G Router
I forgot the password to log on to my router. How do i find out what that is?
Hi, the default username and password for the WRT54G router is "admin" for both. If those don't work, you can reset the router by holding in the Reset button, which will set it back to those default values.
Thanks for using FixYa!
Feb 09, 2011 | Linksys Wireless-G WRT54G Router
I changed my password but I forgot it
Do you have a Linksys router and you have forgotten your password or you want to reset the password to the default. Firstly you must have physical access to the router. This article is basically for WRT54g and model BEFW11S4
If you have changed the password from the default password and have forgotten the default or your router did not come with any documentation.
To regain access to the router try the following. In the username field leaveit blank and in the password field type admin
Username / leave blank
password / admin
The Rest Button on a Linksys Router
To reset the router
While the back of your router might look different, the reset button is usually clearly marked. To reset the router to the default password, insert something thin--like a pencil point--and depress the red button. Hold that for a few seconds. The password for your Linksys router should have reverted to its default.
Try accessing it from a machine that is plugged directly into it. The default address is usually http://192.168.1.1. When you gain access to the router then you can change the password to any word of your choice.
May 28, 2010 | Linksys Wireless-G WRT54G Router
Just received the WRT54G router and wireless card from a friend...the router works, but I can't get the wireless to work without the original password, however my friend can't remember it. Since i have...
You can reset to default factory settings.
check here for a full list of default password
or follow these instruction:
"f you have forgot the default password of your linksys WRT54G router than remember that the default password for WRT54G is user name = not required /give any
password = admin
and the default access IP of WRT54G is 192.168.1.1"
and here for a configuration tutorial of your device.
Of course resetting values you have to recreate network configuration this tip can help.
Aug 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
How to change my security password for my computer because I forgot my password and I own a linksys router wrt54g THANKS FOR THE INFO
This answer is not specific to your router but, most wireless router have a 'reset' button on the back. You need to have physical access to the router. It cannot be done remotely. You will probably have to insert a pin or paperclip through a small hole in the back to reset it. You will lose all settings. Then you can log into the router, using the default settings, and set a new password.
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
1 forgot my passwords for each computer on linksys router 54G
You can press the reset button on the back for a minute and it will reset the router back to default.
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Forgot password
to reset, also you need to press it for about 5 or 10 seconds.
Jun 28, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
140 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
