I justpurchased a toshiba satellite laptop and a iconcepts wireless keyboard and mouse. I cannot turn on the keyboard even though I have added batteries. can you help?
I have inserted the batteries and placed the receiver by thecomputer but it is not receiveing it
-   I have an acer mouse and keyboard, both wireless and i put in the batteries and click connect but nothin happens. They dont connect, and it didnt come with any software what to do?
-   Guest
I am assuming that this is an INFRA-RED device, with plug and play capability.
1) Make sure that the infra-red port is turned ON on your PC, in the BIOS and in Windows (using control panel)
2) Make sure that the infrared driver is working:
My Computer ==> Right Click ==> Properties ==> Hardware ==> Device manager ==> ....
Find the Infra-red device and check its status.
Some laptops have a mechanical switch witch controls all wireless ports. If you shut-off the Wi-Fi, the blue-tooth and the infra-red will also be disabled.
3) Check for tiny reset buttons on the keyboard, mouse and the receiver. Press them repeatedly.
4) If the device is communicating, and infra-red ICON should appear on you taskbar (RHS).
Right click the icon and make sure you enable IR communications AND plug and play.
5) Make sure you have installed any drivers that came with the keyboard, if any.
6) Again, make sure that infra-red communications are enabled in the control panel.
5) Failing that, it is possible that the keyboard is defective, or the infra-red port on your laptop is NFG, it would not be the first time.
6) You may want to take your keyboard to a computer shop, and ask the staff the try it with a different PC.
Alternately, try a different keyboard with the laptop.
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your...
(More)
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your criteria. It costs less than $65.00 and is easily connected to replace a wired keyboard and mouse.
I have been using two of them for years now, and have never had a problem with them.
They eliminate excess wires, and work like a charm.
the cursor of my mouse doesnt move, i tried to fix it diff ways a number of times..since the buttons...
(More)
the cursor of my mouse doesnt move, i tried to fix it diff ways a number of times..since the buttons seem to be working i dont think there's much wrong with the product. the keyboard works fine and yeah...the red light doesnt appear under the mouse when i press connect after pressing connect on the reciever...plz help
Mon clavier s'est subitement bloqué et je 'ai plus aucune touche active:j'ai...
(More)
Mon clavier s'est subitement bloqué et je 'ai plus aucune touche active:j'ai changé les piles mais sans résutat.J'ai activé "connect" mais cela ne change rien.J'ai essayé un ancien clavier que j'ai branché sur la tour mais, également sans résultat:j'ignore d'où vient ce blocage.Quelqu'un peut-il m'aider? Merci (clavier:logitech cordless keyboard)
