Question about Epson Stylus Color 440 InkJet Printer
Printer cartridge problem
The black cartridge from my epson stylus color 460 printer wont print despite running nozzle check, print head cleaning, and print head alignment. the results are the same with a different black cartridge. only faint dashes appear on the paper for black print.
I am really stuck, help please. What should I do
  • JLO-MISSL Dec 30, 2008
    I have the same problem. I've run the cleaning cycle, done the nozzle check,done the print head alignment and switched to a new print cartridge (Seiko Epson Corp. cartridge). I can print in color but no black printing is in place. I have even cleaned the inside bottom of the cartridge container with a q-tip and rubbing alcohol and run all the tests again.
    Do you have more suggestions? What fo I do next???
    Problem Solver:
I have a 440 and have had the same problem. Of course, I have been using cartridges from Printpal, Inkgrabber, etc. that are not official Epson. I have found that it takes several cleanings and after the cartridge has been in the position for the ink to go down it will start. My last order from Printpal said to set all the cartridges in the position they are in when installed in the printer for several days prior to installation. Of course, every cleaning of the print head uses up more of your ink. You don't have much choice though.
Posted on Aug 17, 2008
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Despite print head and nozzle cleaning, and a new epson color cartridge my Epson Stylus color 880 wont print in color. I've ran the software utility for head and nozzle cleaning as well as using the...
In desperation tried another new cartridge and it worked perfectly first time: I suspect the first was faulty so off to retailer for refund ASAP. At 30+GBP they dont come cheap!
Oct 22, 2009 | Epson Stylus 880 InkJet Color Printer
Epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Apr 02, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus CX7400 Black ink won't print
You are a ******* and I WILL NEVER BUY A PIECE OF **** EPSON AGAIN...THESE PRINTERS ****
Jan 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing partial color no black
Did you remove the plastic protector on the ink cartridge before you installed it?
Nov 06, 2008 | Epson Stylus Color 1160 InkJet Printer
Black cartridge problem
Hi , good day , try to do head cleaning until the black print will appear perfect in color.
May 05, 2008 | Epson Stylus Color 460 InkJet Printer
Epsom stylus color 460
Hi , i hava same printer like this , the printer need to reset , the counter are exceed the limit number of copies printed so need to reset the printer , you may visit the web site enter the printer number so they wiill able to identified the machine for downloading reseter.
Feb 25, 2008 | Epson Stylus Color 460 InkJet Printer
Epson Stylus Color 440 InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
