Question about John Deere 4000 201000-> Gas & Diesel Tractor Radiator
My F935 John Deere mower has a PTO issue. After mowing for about 20-30 minutes the PTO light starts flashing and the alarm goes off. The blades are still turning tho. Any direction you can give me on how to fix this and why it is happening would be most appreciated. Thanks
  • farmerbear
    farmerbear Aug 28, 2010
    if you have multiple speed settings for your PTO , you may have it set on too high a speed for that implement. Not a solution, just a thought. :)
    I'll keep thinking on it.
    Farmerbear
4 Suggested Answers
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
Blades won't engage on John Deere x540.
I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
Jul 29, 2017 | John Deere Garden
I have a John Deere Sabre 1948 Hydro while mowing if I go in reverse the engine wants to cut off. What causes that?
It's a safety mechanism that will automatically shut down the PTO or blades. That's what you have going on. It's normal.
Oct 08, 2015 | John Deere Garden
Blades disengage after mowing for a while on John deere x495
This could be a couple of things. Your pto clutch could be going bad. Or, if you loose charge from battery your pto will shut off as well. I would check volts across battery terminals, then start unit and raise rpms and note the change if any. If there is no change in rpms from stopped,idle, to high rpms you have a charging issue that would cause this problem. If charging system checks out your problem probably lies in pto clutch. Hope this helps,good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 10, 2013 | Garden
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
I have a john deere gt242 mower, when i pull the pto knob to turn blades on they wont turn on. What could be the problem
Could be debris in or around the assembly,check under the fenders too.Check the tension on the belts.Good luck and happy mowing.
May 11, 2011 | John Deere Garden
F935 re-aliwning drive shaft for deck after blade change?
If you look close at the splines of the shaft you would see 2 of the splines are pinched together at the end of shaft and on the recieving end of shaft you would see that there is a small cutout where the 2 "pinched" splines would line up when slid together.
May 16, 2010 | John Deere Tractor 1020, 1520, 1530,...
John Deere 4000 201000-> Gas & Diesel Tractor Radiator Logo
472 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
