Looking 4 jumper settings on a ibm thinkcentre 8143-34u. all my removable jumpers were taken off now i can't figure out what pin #'s to put them on
sandrew
  • 2961 Answers
SOURCE: Jumper settings on 8307-48U mainboard
Have you loked at this page, apologies if no good, but there is a setup manual http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42970
Posted on Feb 12, 2007
SOURCE: maxtor 40gb hard drive
i think it's a conflict with the two hard drives maxtor (ata) and westen dig(eide) ,.....could be wrong....maxtor 40gb....west,260gb let me know
Posted on Sep 17, 2007
SOURCE: jumper pin settings
Hold the samsung SP1203N hard drive in your left hand with the lable facing upwards (then power cable connectors will be on your right hand side and the IDE cable connector will be on your left ahnd side). There are two raws of jumper pins in between the above two connectors
Master - join the first two column of pins on the left with a vertical jumper
Slave - leave all pins free (without jumpers)
Cable Select - join the third column of pins from the left with a vertical jumper
job done !!
Udai De Silva
Posted on Jan 08, 2009
  • 211 Answers
SOURCE: slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Posted on Mar 29, 2009
cyberware
  • 196 Answers
SOURCE: Looking for the jumper pin settings to designate
on the right hand side put the jumper to make primary master
Posted on Sep 01, 2009
Dell 4700 need to reformat but need to get admin code for the bios. already took bios bat out and unplugged all cords on inside and re-plugged them. got system code, but still need bios admin code is there...
I believe that you need to set up the CMOS jumpers inside the main circuit board. For details click on this link (Click Me)
1. Look for 3 pin CMOS clip that says CLR CMOS on the mainboard 2. Take out the jumpers from 1 and 2 3. Put it in jumpers 2 and 3 and wait for 5 seconds 4. Put it back to jumpers 1 and 2
Figure 1. Schematic Diagram of Main Board Dimension 4700
Thank you for choosing Fixya
Jul 06, 2011 | Dell Dimension 4700 PC Desktop
I want to know the Jumper settings (Master and Slave) for IBM Travelstar 15 GB Hard drive. I would be glad and thankful if you will solve this problem for me. Ari Kiviharju
This solution will reference the picture below:
To configure the drive in Master mode, no jumper setting is used (Figure A1).
To configure the drive in Slave mode, the jumper must be placed over the two vertical pins on the far right (Figure A2).
To configure the drive in Cable Select mode, the jumper must be placed over the two pins in the bottom row (Figure A3)
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Computers & Internet
IBM THINKCENTRE A51p WIN XP PRO/SP3 1GB RAM ALL MICROSOFT UPDATES ARE CURRENT BOOTS QUICKLY WITH 1 SATA HARDDRIVE (1.5 MINUTES) BOOTS SLOWLY WHEN 2ND SATA IS ADDED (5 MINUTES) ONCE WINDOWS...
it seems as they are conflicting this u usually caused by jumper settings you need to download the utility program from the hdd manufacture the utility allows you to change hdd priority you need to change the settings on the second hdd to slave and the first hdd to master but like i said unlike ide which has jumpers sata has digital jumpers the utility from products website is needed for this
Sep 02, 2010 | IBM ThinkCentre A51 PC Desktop
I have an IBM ThinkCentre m51, no os installed and it has the wrong BIOS. It boots up but keyboard & mouse are dead so it seems like I cannot flash the bios, check it or install anything.
Try removing system battery on MB for about a minute and reinstall. Some units have a jumper pin for reset on MB also. If that does not help, your MB may be bad.
May 05, 2010 | IBM ThinkCentre M51 PC Desktop
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Remove Bios Password ibm t40
ON YOUR WINDOWS ENVIRONMENT open command prompt, or MS DOS prompt type this:
debug
o 70 2e
o 71 0
q
Then restart...
Oct 21, 2009 | IBM ThinkPad T40 2373 Notebook
I cannot reboot, the thinkpad is locked. how do i
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 11, 2009 | IBM ThinkPad T43 Notebook
Need to bypass or hack the bios password for IBM X41 PC Desktop
okay guys i found i new way to reset the pass with only a screwdriver …
will try to make a site with a tutorial to reset the tmp chip .. i think it works on every ibm notebook
here is a picture from an IBM X41 tablet i reseted the pass today
http://ug1.kw.cx/ug/0257/1549/123784929_full,r,470×470.jpg
you have to put the screwdriver between the 2 pins to contact them .. and now power on ya machine and go to the bios … you will receive a message with an security chip error or something like that
this chip was on the bottom of the mainboard … i think the T Notebooks (T40 , 42 , 43 , R50, R51 have the chip under the touchpad
will share this here for ya guys
i trade with used computers so you have to try many thigs to delete passwords ^^
The same way to delet passwords on DELL (D610, D600, and many more)
greetz Adrian
Mar 27, 2009 | IBM NetVista X41 PC Desktop
IBM Thinkpad T23 2647 Power on password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
Mar 03, 2009 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
