Question about Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
How do I take apart my Price-Pfister 533-5C Kitchen Faucet to replace the rings for a leak?
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
  • 4 Answers
SOURCE: kit. sprayer/hose
watch this http://www.pricepfister.com/about/diverter.aspx
Posted on Jul 02, 2009
meBNme
  • 334 Answers
SOURCE: Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Posted on Aug 24, 2009
Testimonial: "As you suggested, the faucet was under warranty and Price Pfister is sending me some parts at no costs. Hopefully, the parts will resolve the issue."
SOURCE: Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Posted on Sep 15, 2009
  • 336 Answers
SOURCE: how do you take apart the price pfister 533 50?
On the under side of the handle is a plastic plug its either red and blue or its a logo about 1/4" dia., remove that and there is a set screw that attaches the handle. Loosen that screw just enough to pull the handle off. Then you can disassemble the faucet for repairs. Price Pfisters have a lifetime warranty, if the cartridge is bad you should contact them for a replacement part.
Posted on Sep 16, 2009
My kitchen Price Pfister faucet is starting to "squeak" when I turn it on or off. What's up?
dry rubber "O" ring/ threads on the shaft
call a plumber to pull it apart , replace the seal and lubricate it
Dec 04, 2016 | Price Pfister Plumbing
How do I fix a leaky Price Pfister Treviso 49D faucet.
Download the instructions from the manufacturer.
Dec 28, 2014 | Price Pfister Plumbing
My kitchen faucet handle makes a screaming sound and will not turn the cold off
Either you didn't seat the o rings properly or they are the wrong size or the cartridge needs replacing
Jul 18, 2014 | Price Pfister Marielle Kitchen Faucet with...
Price pfister kitchen faucet spot leaking at joint
They are wrong. There is no O-Ring at the swivel joint and it is NOT serviceable.
May 20, 2012 | Price Pfister Plumbing
Price pfister pull out kitchen faucet starting leaking suddenly and profusely at base, from joint segments along handle base, directly under handle and possibly at base of faucet. Understand I need to...
Most likely it is under the label , it is normally put on with light adhesive. That is where the set screw is most cases. As far as leak goes, your on right track with 0 rings/gaskets. Be careful however, some time you can just get one at hardware store ( whole unit) already together almost as cheek as repairing this unless it is just a couple 0 rings.
May 27, 2011 | Price Pfister Plumbing
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
How do you take the water assembly apart it leaks out the top of the assembly.
Pop off the cap on top of the faucet, unscrew the philips head screw,pull faucet up and off the brass center and replace the two o-rings you see .
Feb 15, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have a price Pfister Marielle kitchen faucet. The valve body leaks when handle is in off position.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Aug 28, 2009 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap... Logo
250 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
