Question about HP Computers & Internet
The display isn't coming on and there are two lights blinking aroung the key board
    Scholar:
  • 156 Answers
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Posted on Aug 29, 2010
All display lights blink
You will need to replace the main board on the back of the unit. Here is the board to order. Be sure to program the board when you install it. There will be instructions that come with the board.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
My HP Compaq 6730b screen isn't coming on. All the
Does it seem like the laptop booted up all the way except the screen is black? If so try the steps below:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 16, 2012 | Compaq Computers & Internet
GE Profile refrigerator pss26sgrcss isn't dispensing water, and 2 days control panel isn't working either. Not running and not cold at all, what are possible problems and solutions?
check for power at the display if power is present then you need a new interface (display) if no power is there then you need a new mother board located on the back of the unit square panel..mother board part#- WR55X10942--interface (display)-part#WR55X10390
Mar 27, 2012 | Refrigerators
Panasonci Viera 50
10 blinks is the Miscellaneous error code. Your TV knows something is wrong, but isn't sure what it is. It can be any number of things, including bad boards. Generally A red light blinking 10 times means that a video board has gone bad. viz.
Sub 5v SOS / Main 3v SOS DG Board/ DTV 9v SOS / Tuner Power SOS
Jan 10, 2012 | Panasonic Televison & Video
Sanyo Projector PLC-XP57L. Bulb lights ok, no image display not even the ' Menu' . Only white screen is displayed.
If the menu isn't coming up then the TV video board may be faulty as otherwise it would appear. If you can still return you should go to where you bought it and ask for a replacement.
May 04, 2011 | Televison & Video
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
Computer power light comes on and just blinks. tried shutting off and turning on and does the same thing.power went off in house yesterday when we had a storm .power went off for about a second and came...
do you have a dial up modem installed in the system's pci slot? try removing it and see if it posts then. if it still doesn't post (show bios screen) then try using a known good stick of ram. if it still doesn't display then chances are its the power supply.
Dec 08, 2009 | Dell Dimension 2400 PC Desktop
Canon Copier Key Panel Problem
Replace display touch control panel
Deshpande +919420906982
Oct 19, 2008 | Canon imageRUNNER 400S Copier
Computers & Internet Logo
55 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
