Question about JVC Televison & Video
AV-36D800 - Color is messed up. I have tv sitting
AV-36D800 - Color is messed up. I have tv sitting on a 850lbs gun safe. It looks like a magnate is on the side to the TV. Could the gun safe through the colors off?
  • 2,973 Answers
Yes it could very well do it. Could you rotate the TV or the safe? Or better still, place the TV on a wooden table.
Posted on Aug 28, 2010
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have full sound but no picture. the screen is completey dead
JVC av32750 tv works for a while and then picture goes out but sound remains on
Oct 06, 2010 | JVC AV-36D800 36" TV
Tv just shut off and won't power up. No lights nothing. Tried unplugging and plugging back in. There is power to the outlet. I told my dad it was toast.
You are correct. If you get no image or text from the screen indicating it is trying to operate then it is time for replacement or service.
Sep 25, 2010 | JVC AV-36D800 36" TV
My samsung hcn529w rear projection tv has convergence problems. how can i manually adjust the color guns
you are reaaly looking for a nightmare messing with the convergence rings to adjust the convergence you need to change the two ics and probly some reistors
May 18, 2010 | Samsung HCN529W 52" Rear Projection...
Color in corner going bad
U drop this tv before,like CRT yoke in cathode ray tube have big jumbo.Any magnatic around also,Tries moves the the difference directions might help,like northwest,southeast,so on.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Too much yellow in picture
The problem with the set is that the blue gun has gone weak, and not emitting at par with red and green guns in your picture tube. Turn of the blue screen and get the grainy display on the screen (detach the cable) and enter into service mode to fine tune until you get a perfect or black and white grain pattern.
Dec 19, 2007 | JVC AV-27230 27" TV
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jun 06, 2007 | JVC AV-56WP74 56" Rear Projection...
Tv problem
I assume you get a picture in there somewhere? The discolorization is caused by the degauser circuit malfunctioning or un-shielded speakers sitting too close to the TV causing magnatism in the CRT (picture tube).
Apr 08, 2007 | JVC AV-32F802 32" TV
Help!!!!!!!! could die if u dont!!!!!!!!
Hello. Maybe you have a magnetized display. To get rid of that, plug your tv out from the mains and find a soldering gun (those used by electronics guys). Place the lateral of the gun near on the front of the display (touching the glass) press the button and slowly move the soldering gun around all the surface of the display. Carefull not to touch anything or yourself with the tip of the gun, it get's hot. Do this for about 2 minutes. Then power back the tv and check if something is different.
Feb 26, 2007 | Panasonic CW-C101MU Air Conditioner
Televison & Video Logo
143 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
