Question about Garden
I have a 145 amp 240volt Century Mig Welder that's about 15 years old. It hasn't been used that much over the years, but was used quite a bit lately on a go kart project. It performed pretty well until the end of the go kart project. I have always had to adjust the wire speed higher than the manual says to to get it to weld properly. Now I can't seem to get the wire speed adjusted properly. The arc or wire speed seems to be unstable. It gets worse as you weld and the welder heats up. It trips on its internal protector much sooner than it used to also. Would this be a transformer problem, gun problem, wire feed problem, or wire problem. It seemed to happen when I changed to a new roll of wire and a brand I have never used before (from Home Depot). I am using Argon/CO2 as a shielding gas. Thanks, Tim
3 Suggested Answers
  • 760 Answers
SOURCE: have a dayton 85 amp
You didn't indicate what thickness of metal you were welding or what type of weld wire you were using (other than size)
Less expensive welders will have voltage present, with trigger off. Shield gas= positive nozzle, flux core= neg nozzle.
These machines are probably abojut 15% duty cycle. That means you can only weld a few min. As far as tripping breaker on max setting, that is probably not unusual. If you read the label on the welder, I would imagine the max line current is over 20amps. This should be on at least a 20A seperate circuit. If I remember correctly, the FLA amps on this machine is over 20a
Check input voltage and be sure you're not experiencing a voltage drop. A small voltage drop will create a dramatic amperage increase on your supply circuit.
Posted on Aug 18, 2010
agent91
  • 2100 Answers
SOURCE: clarke 135 -gas/no gas- mig
Any welding supply or a welder with bottle exchange should carry all the gauges and gas you need. There has to be one near you. We live in a cow town here and we have a bunch of them. Check it out, hope this helps.
Posted on Dec 20, 2010
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
Im looking into getting a mig and have come across the century (by lincoln) welders for 299. is this a quality welder and of same quality as a Lincoln brand.
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
Jan 01, 2011 | Lincoln Electric LE 83180 Century...
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Owners manual for a century wire feed 83160 mig welder
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
Garden Logo
342 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
