Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw not cutting straight - Husqvarna "Chain Saw - 16" Bar, 3 Hp
  • 43,501 Answers
The problem is that the chain is dull on one side...you hit something on one side of the chain and dulled the teeth on that side and now it tries to cut in a circle....
Either get a new chain...sharpen the chain your self... this is tricky if you have never done it before...or have a pro sharpen the chain...
heatman101
Posted on Aug 28, 2010
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My chainsaw will not cut straight after chain was shrpened because I hit a rock.
If the chain is still not cutting straight, it is because it is not sharpen correctly...the cause of it cutting crooked is because on side of the teeth are sharper then the other side...getting it to cut straight again can be extremely difficult and time consuming...the teeth must be equally sharp and the depth gauge (or aniti kickback) part of the teeth also filed to the same dimension...
Often it is easier to just buy a new chain...
heatman101
May 08, 2011 | Husqvarna Garden
Chainsaw cuts at an angle.....Why
The most common reason for this is uneven sharpening of the chain. Closely examine the chain and look for one ise to be worn more than the other. Try sharpening the dull side If sharpening is not a possibility, install a new chain. If the new chain also cuts to one side than the bar needs to be repaced as the chain is not being held straight.
Keep us posted,
Dan
Dec 23, 2010 | McCulloch Garden
Chainsaw does not cut straight, veres off at an angle only happened since adjusting the chain ,is there an adjustment for this?
Typically this is a problem with sharpening the chain....if the chain has been sharpened unevenly (different angles on the cutters) it will drift to one side. Also most people tend to be more comfortable sharpening one side than the other and the teeth on that side will get worn faster.
As long as it is that right chain for the saw / bar and it is sharpened evenly it should cut straight.
There is no adjustment per se.
Take care.
Dec 06, 2010 | Garden
I have a poulan pro chainsaw. It runs fine when the bar is straight up and down, but when I cut with the bar horizontal it cuts off.
clean the gas tank,lines and filter.Replace the spark plug.Mix gas and iol properly = one small 7.5 onz bottle in 1 gal of gas.
Oct 26, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Cuts crooked
A saw wont cut straight if the cutting plates are of different lengths or blunt, due to improper sharpening. Take it to a repair shop or a hire centre and they might put it right. You might be better with a new chain. Stephen.
Dec 06, 2009 | Garden
I have a husqvarna 350 chainsaw, it wont cut straight throuh a log without cutting at an angle and getting jamed. what is the problem , any sharpening tips
THE ONLY THING THAT CAUSES A SAW TO CUT ON A CURVE IS THE CHAIN IS SHARPER ON ONE SIDE THEN THE OTHER AND IT PULLS THE SAW CHAIN TO ONE SIDE CAUSING THIS PROBLEM.
THERE IS NOTHING WRONG WITH THE SAW, IF YOU USE A FILE TRY A FILE GUIDE THEY WORK GREAT
Sep 17, 2009 | Husqvarna Garden
CHAINSAW NOT CUTTING PROPERLY
Sounds like your chain is too loose, try tightening it.
Jan 05, 2009 | Dremel Variable - Speed Multipro Rotary...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
158 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
