Sanyo ST-21G1 dead set
I found that Shorted (K2647) MOSFET in primary section of SMPS resistors 1 ohm and 10 ohms open/burn. i try to replace then check all the primary components. all are ok but still no oscilation. i check linear side of the power supply i found 300 volts DC in Filter capacitor.
please help....
  • djlans_12058 Sep 04, 2008
    sanyo st-21G1 dead seat and i replace k2647 ;resistor 1 ohm 10 ohm and TT2140 . i try to on it is ok but 1 day only dead set agian and i need a diagram couse the resistor are burn i cannt find the value.. help me pls......
  • Anonymous Mar 27, 2014
    the power supply cannot hold a steady voltage. I already changed the regulator but still the same result.
  • 4,234 Answers
There should be a small valued cap in the primary side (22ufd?) at 250V. Check that. Also, look for other small caps int he range of 2.2ufd with 200V ratings in the same general area.
Dan
Posted on May 07, 2008
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
Lightning damage
Replace the parts with the original ones, a .5 ohm difference on a resistor on the video circuits will cause the unit not to work correctly.
Sep 27, 2008 | JVC HR-XVC27U DVD Player/VCR
A sudden burst of high volume from a CD player rendered this Onkyo TX 85-11 dead. The volume was at the highest level ... necessary to run an Ipod through the receiver. When we switched to the CD player,...
This is a 2 channel stereo unit. Ebay shows @ a dozen of them for sale between $46- $90. In davenport Iowa, which isn't an expensive area, you can't touch a repair for that. Check your area Our estimate fee alone is $43
Oct 23, 2017 | Onkyo TX-8511 Receiver
Sanyo tv model no. ST-21G1 power indicator is just blinking it does not oscillate the horizontal output. what is the possible problem or parts to be replaced?
Check if Horizontal ouput is shorted.Check if you have B+ (135VDC) power supply and secondary supplies working(12VDC, 5VDC) and check if you have horiz. drive pulse from drive transformer.
A common fault for dead set is the capacitors in the power supply (secondary of transformer) - no 12VDC supply.
Oct 22, 2009 | JVC AV-27950 27" TV
I Need values of resisters R-82 and R-85. They feed plus and minus voltage to power amps. amps shorted and burned resistors. The amp is a subwoofer amp in a B & W model DM605 s2 speaker. Any help would...
If the resistors were blown, the power amp which is either transistors or an amplifier package has been shorted out. The resistors are very low resistance, and used really as slow blowing fuse. The value is probably a fraction of an ohm (eg. point two ohms)
Aug 11, 2009 | Audio Players & Recorders
TV will not turn on
Replace shorted Q431,can use a 2sc3998, open r448 .47ohm resistor. after you get set on beware of convergence ic's may have been shorted causing all the problems.Check r859 &r858 .47 ohm 1 wtt that supply - &+ 20 volts to convergence packs, if open replace packs & check low ohm resistors on convergence ,I found r2144 &r2145 open replaced & all systems go "good luck"
Dec 26, 2008 | Akai PT5598HD 55" Rear Projection...
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
Parallel connection of power mosfets with two of 5 smoking
The IRFZ46N are n channel high speed switches . They basicly drive the Mosfets. Sounds like you have some problem there my friend, and unless you paid alot for this amp. Its going to need probobly all the n channel switches as well as every mosfet + the bias resistors repalced. Before plugging in the amp jump out the fuse with a 100 watt light bulb.. If the bulb glows brightly when you apply power there is still a short in the unit and could be in the switching power supply section of the amp. If it glows bright and dims, The shorts are most likly gone. The bulb will minimize the amount of current the unit can draw and most of the time wont let the new parts blow out. Check out this service number and see if they can help you. Good Luck Main support number 978-823-0300
Jul 26, 2006 | Pyramid PB779X Car Audio Amplifier
Televison & Video Logo
354 people viewed this question
Top Televison & Video Experts
