Question about Frigidaire CWS3600AS Top Load Washer
We have a Frigidaire top loading, 8 cycle, heavy duty, super capacity 2 speed washer and it does not have a model number on the inside lid. The washer is leaking at the point where the drive shaft connects to the drum. Is this something that we can fix on our own or with some explanation, or is it something to call a technician to fix? Also, would it just be a better idea to buy a new one? They aren't too expensive anymore... Thanks
  • 1,531 Answers
The part needed to be replaced is the main tub seal and it is not hard to do. remove the agitator the you will see a collars that has two bolts on the side of it this keeps the inner tub attached to the drive shaft you may also have one that is broken.
lift the washer lid. then remove the tub ring that is on top of the outer tub once this is removed you can remove the inner tub.there will be a brass ring with a black rubber piece in the center of it this need to come off in order to get the tub seal out. it maybe a little difficult toe remove but it just pulls up. you may have to use some liquid soap on the drive shaft to make things easier to slide up and off
Posted on Aug 28, 2010
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
I'm just a tentant asking a question before calling maintenance. Is the agitator suppose to only turn in one direction? I thought it was suppose to be a back and forth movement. This model is a...
You have a 2 part agitator.
The bottom portion moves back and forth. The upper corkscrew moves clockwise only,pulling the laundry down and around the tub.
Jul 21, 2011 | Estate ETW4400VQ Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire CWS3600AS Top Load Washer Logo
461 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
