Question about Microwave Ovens
Its brand new so i'm not sure how it should run. here are my questions and observations. 1. it hasn't stopped running for two days and its the loudest appliance in the kitchen. why? 2. the overflow pump is running frequently. the ice is wet because the temp his set to high. 3. it sounds like water is pouring in the unit. not a normal sound. 4. what should the temp be? Is all this normal?
  • 490 Answers
Howdy. I'm guessing you have a new refridgerator with a built in ice maker. although I don't know what the overflow pump might be, the running water sound is likely the ice tray filling.
If the running water sound is continuous, then there is a problem and the water valve that supplies the fridge should be shut off. By now you have likely turned down the temp in the freezer section a little, so I will move on to tell you that the new fridges are mostly ridiculously loud and make as many as 30 different, unsettling noises. Many will even be so bold as to mention this in the user's guide. Ideally, once it has settled in, made its bucket full of ice and come down to happy temps, it will quiet down a little. All you can do is keep it as full as possible , as this helps it stay cold better and is more efficient.
I hope this helps some:)
Farmerbear
Posted on Aug 28, 2010
Kitchenaid KBMS1454BSS Starts and stops, then restarts and stops, etc, at different intervals.
PDF]BUILT-IN MICROWAVE OVEN Use & Care Guide - KitchenAid
www.kitchenaid.com/.../KBMS1454BBL/Use%20and%20Car...
KitchenAidWe have provided many important safety messages in this manual and on your appliance. Always read .... Touch CANCEL/OFF and reset the clock if needed.Missing: kbms
KitchenAid kbms 1 Kitchen Ranges Questions & Answers ...
www.fixya.com > Forum > Tags > kbms 1 > Kitchen Ranges
KitchenAid kitchen ranges kbms 1 related questions and answers. ... Control panelreset answer Steve, Thanks for providing your answer to my question about ...
Nov 07, 2015 | Microwave Ovens
I bought the microwave brand new two years ago. It always had one or two problems. The problem I am currently struggling with is that we you want to microwave or defrost for more than 1 minute, the counter...
-Base on my experience. These days microwaves are cheap. I Prefer to buy new one instead buy replacement parts , end up 30-50 dollars but it still not work properly.
-Good luck
Mai
Dec 22, 2017 | AEG MCD3534EM Stainless Steel 900 Watts...
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
STOP BEFORE THE TIME EXPIRY AND NOT WARMING THE FOOD
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your exact symptoms, as well as the answers to these questions:
- How long does it run until it stops?
- Is there and error or fault code in the display, such as H97, H98, etc.?
Nov 23, 2009 | Panasonic NN-T990SA Microwave Oven
Runs 5seconds then cuts off
Please post a new question, and please include your brand name and the full model number from the tag in or on the unit as well as detailed symptoms so we can help you.
Oct 08, 2009 | Panasonic Microwave Ovens
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
Timer runs extra fast and microwave does not heat
I had this same problem with my Maytag Microwave. Unplug the unit and plug it back in. It fixed my issue.
Sep 04, 2009 | Maytag Microwave Ovens
Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Sep 21, 2007 | Dacor PCOR30 Convection/Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
