Question about Microwave Ovens
Power on, but when control dial is turn nothing happens. Occasionally it will start working. Is something loose in the switch/dial?
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 28, 2010
My GE profile Convention Microwave model JVM1790SK01 dial is loose and does not work. How can this be fixed?
see the information and use the common sense: God bless you
. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Sep 07, 2012 | Microwave Ovens
Bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
Jun 02, 2012 | Bosch HMT8656GB Microwave Oven
The microwave occasionally shuts itself off. The
You are tripping a high limit switch which means the cooling fan is busted or the microwave is installed to close to something. That or your door interlock switches are sticking.
Dec 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave Oven model JVM179SK01. The dial button does not work. It is not stripped as someone suggested before. You turn the dial and nothing happens, you push it in to make a selection...
Are you certain there is power to the unit?
You could have a bad latch switch or other component (fuse, other switch, etc.). To determine which it is will require having a volt-ohm meter and knowing how to use it, and the wiring diagram for the appliance, which can usually be found inside the unit somewhere.
Let me know if you want to tackle this, and I will help you as best I can. I do not have a wiring diagram to look at, but will help you to read it.
Dec 11, 2009 | GE JVM1790 Convection / Microwave Oven
My lg intellowave microwave will not work correctly when you set the time and press the button it starts to count down but nothing happens the dish does not turn
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can download many LG service manuals here, but strangely, they do not have part numbers in them.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
If you don't find your model's service manual or need more help, feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 26, 2009 | LG Microwave Ovens
Microwave won't heat.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Nov 28, 2008 | Jenn-Air M170 Microwave Oven
Microwave not heating up
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you do not find your model there, Please reply back with your brand and model number so we can help you.
If you only need a switch, you can order one from us for $5 postpaid.
Sep 16, 2008 | Microwave Ovens
KitchenAid Built-in Microwave Oven
If the door switch is not properly activated when the door is closed, the controller thinks the door is not shut and it will not start.
Sep 11, 2008 | KitchenAid KEMC377K Convection / Microwave...
Microwave won't operate
Sep 09, 2008 | Microwave Ovens
Start button
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
On these models, the problem is usually a broken tab on the upper door switch mount.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Jul 22, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
