Audio becomes fuzzy and volume decreases, have to raise volume to max to produce some audio, changed out 3 capacitors on sound board, as previously suggested, played normally for about 50 hrs then problem returned. What if I swapped out 25v cap for 35v cap?
  • 1 more comment
  • mjmouze Aug 28, 2010
    This is for an RCA L26WD26D
    forgot to mention this is for RCA L26WD26D TV/DVD combo.
    This is for an RCA L26WD26D TV/DVD combo- is swapping out the capacitors my only option other than swapping out the entire board? I don't see any other components that can be changed by my amateur skills.(see previous posts)Regards-Frank
  • 10,594 Answers
I think main board replacement will solve your sound problem and main board is available with Shop Jimmy for $162, click that link to see image of board and price info.
If you want to repair tv on component level as few capacitors have been replaced then I would recommend to resolder sound output chip pins that is mounted on big aluminum heat sink and surrounding parts as well because any lose/ dry soldering connection can be cause of low sound output.
Swapping 25V and 35V capacitors would also be helpful to fix the low sound issue.
Hope these info will help you.
Thanks.
Posted on Aug 28, 2010
  • 11,800 Answers
Yes, apparently those capacitors are undersized. Measure the voltage on them then add 50% as a safety and buy them.
  • Azrael SRL Aug 29, 2010
    I don't think there's something else that is faulty there, so change them. But, as i said, measure the voltages and try to find out if all the part on the power source are ok.
Audio has stopped working. Pops when raise volume. Volume meter increases and decreases but no sound. Can this be fixed?
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 13, 2015 | Audiovox fpe 3207 32 in. LCD Television
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
How to boost a mic in the sound input jack of the Bose Companion 3 Series 2? My voice definitely come through nice and clear, but it's very soft, even with the Bose and laptop volume on max.
Maybe an amp t be useful to increase volume
First try to find on board ssoftre on the PC to add some bass/midrange to it. If there is none you can look at finding something that can produce the effect I think. Thinking of somebody like Kendrick Lemar who changes his voice so much that I don't know what it
really sounds like.
If that does not workMaybe going through a hardware equaliser might do the trick
GOOD LUCK ... HOPE YOU FIND THE ANSWER
http://download.cnet.com/Expstudio-Audio-Editor-Free/3000-2170_4-10444774.html
I have added a few links below
Jun 17, 2015 | Computers & Internet
Whichever direction I turn the volume control knob (clock or anticlock wise), the volume always increases. I cannot turn the volume down
There's a endless volume knob who has contacts to inform if the volume increase or decrease.
It's normally produce noise and the circuit understand it like a data.
You can put a 1uF/50V capacitor in the each of 2 soldering points of the volume control to the ground (there has 3 points. One is ground and the others are live).
Best regards
Jul 24, 2011 | Cambridge Audio Azur 740A 2Channel...
What are the functions of the keys on the dell 1745. F1, F2, keys with the symbols above them?
Fn + F1 Change Display Device. Fn + F2 Wireless Control Fn + F3 Battery information Fn + F4 Decreases brightness on the integrated display only (not on an external monitor). Fn + F5 Increases brightness on the integrated display only (not on an external monitor). Fn + F6 Keyboard backlit(available only if a backlit keyboard is installed) Fn + F7 Mute Fn + F8 Decrease audio Volume. Fn + F9 Increase audio Volume. Fn + F10 CD Previous - Play previous media file. Fn + F11 CD Play/Pause - If there is Audio CD in system, Media player will play music. Fn + F12 CD Next - Play next media file.
Jan 08, 2010 | Dell Studio 17 Notebook
Volume automatically decreased to zero and won't go back up.
Plug the audio out to check it isn't the speaker itself failing. I suspect it is the audio circuit section of the board. But a few times I have experienced the speaker unit circuit where the magnet is caused the problem. So using an external speaker helps to determine speaker vs circuit
Thanks for using FIXYA
Oct 11, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
Bose Companion 5 Producing Unstable Sound
The intensive bass is making the speaker shake very much and that could have caused a short that changes the volume after a while when the speaker has been shaking for a period of time. You could try lowering the bass or volume to see if it makes a change in how long it takes to make the volume change.
Oct 18, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
