Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I have bissell cleaner 8920 it will not release the cleaning fluid and water
  • 276 Answers
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray, contact BISSELL Consumer Servies at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Posted on Sep 28, 2010
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a Bissell Proheat 2X (model 8920). The problem we are having is when water/soap is initially released (all settings) it continues to leak out the front water spray nozzles unit the water...
Return it. It is faulty and should not do that. Mine does not. Does require changing water about evrery 10 minutes but one can see the filth in the water. Also re-clean with plain water over areas that were cleaned to remove all cleaner. Old cleaner in carpet to dirt is like a bug attracted to a bug zapper. It can be time consuming, but it will pay for itself and can do a great job if you pay attention when water or cleaner runs out, otherwise it will not clean properly!
Jan 30, 2011 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Model # 8920 bissell steam cleaner wont **** up the water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 //
Dec 27, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell proheat 2x 8920 brushes aren't working
heatman101
gjkklgj
After three months of use it stopped releasing water from the bladder. I have a bissel proheat 2x model #8920
sound like the pump fail, it will also cause solenoid to fail and need replacing 19.00 bucks pump and solenoid 11.00 bucks, easy and cheap to replace yourself. go to provac.com for parts. even if you get both part but one still working it good to have that extra part laying around since you going to keep the vac for awhile.
Aug 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 8920 won't release fluids at the rollers
I have an 8920 ProHeat 2x as well with the same issue - no spray at the rollers. Seeing that the hand tool worked I checked the finger switch for continuity and it was good. Turns out the red spray heads that clip into the unit just under the water tanks were the culprit. I popped those off and ran a paper-clip through them from the front. I must have contaminated the fresh water tank while emptying the grey tank. Works better than ever now, just thought I'd share what my issue turned out to be.
Oct 10, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
182 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
