Sir I want to turn on my auto restart feature on my lg ts-c 186 Klm2 Ac. Which is turned off after Service by my local fixer. Please Help. Thank You Suleman Talpur
  • 70 Answers
There should be a auto option on in the mode setting.
Posted on Aug 28, 2010
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
Our requaired is without any in puts(remote start and Manula Start) AC staret after power restart,please gaide to me.
first you need to check if your A/C has Auto Restart function. How?- turn power On from the circuit breaker, if the A/C unit start working at your last-time program you have the Auto Restart function. In that case you never shut it down by the cutting off the current, forever turn it on/off by the remote controller.
Feb 23, 2011 | LG Heating & Cooling
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
THANK YOU
Are you saying your air conditioner does not work? If so, make sure the ac is mode is select and not on heat. Then turn your thermostate down to around 74 degrees . The heat/cool select is on your thermostat. Good luck and keep in touch.
May 26, 2009 | Heating & Cooling
Memory Module & hardware conflict
Dear Sir
Please try latest service pack from net and check. Some hardware devices are not compatiable.
Mar 12, 2009 | Toshiba ZA2000P02 - Satellite...
We bought a LG phone Model number KU9703GHS on the 10/06/2007. It recently started turning offconstaltly so it was taken back to Optus on the 06/06/2008 still inder warrenty for repair. Today we fetched it...
Have you called their corporate office? 12 month warranty is usually on parts. So if they cant fix it they have to replace it with one of equal value, it is a defect. You should have their customer service number on your bill.
You can also contact LG directly as well. If you need their phone number let me know. That is definetly unacceptable.
Keep me posted.
Thanks,
Lee
Jun 26, 2008 | LG Cell Phones
Freezing
sir have u accidently dropped the phone.. probably in water.... ok check whether it has full charge.. once again switch on the mobile.. if it doesn't switch on better take it to local service station. thank u sir
May 09, 2008 | LG Shine KE970 Cellular Phone
Auto on of
sir it is called freezing.. it is due to bad interrupts.. as far as i know it is good if u get a help of technical savvy or get it done by local service station... thank you
May 02, 2008 | Motorola Mobility C261 Cellular Phone
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
