Question about Dryers
Where can i can a whirlpool awz650 timer knob from? Am in Aussie so need a company who will post abroad?
    Scholar:
  • 150 Answers
Many suppliers look online for parts
Posted on May 07, 2008
Need control knob timer dryer doesn't shut off
If you are stating that the timer knob never moves to the off position, then the timer is probably bad and needs replaced. If you can't turn the timer because the knob feels too loose then possibly the knob is just broken. Timer knobs usually just pull straight off so you can look at the back side and see if the plastic around the shaft hole is cracked.
May 11, 2015 | Whirlpool Dryers
Need new timer dial knobs for whirlpool microwave model no avm 515, purchased in South Africa, but now in Australia?
Have you tried Whirlpool Australia? Or call 1300 363 344?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 18, 2008 | Whirlpool Microwave Ovens
Need new cycle control knob for Whirlpool Model LLR8233BNO
You can order replacement parts online. Here is a site that I have used in the past.
http://www.appliancepartspros.com/top-cabinet-parts-for-whirlpool-llr8233bn0.html
There is a place to search within this model and if you type "knob" without the quotes, it will show you just the knobs for the washer.
Oct 18, 2013 | Whirlpool 3362624 Washer Control Timer...
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Timer not working....turn knob to 30 minutes and it stays on forever! Knob never moves from 30 mins....please help!
Most likely the timer motor or the main thermostat is bad (some dryers hold the timer off until the thermostat says the dryer is warmed up). I assume you have adequate heat since you do not mention any problem with the clothes not drying in the usual time.
Usually there is a wiring diagram hidden inside the control panel or posted inside the back panel. If you can read it, you can figure out whether a thermostat controls the timer motor. (I've never had to work on a Whirlpool dryer control problem, so I can't tell you.)
Mar 08, 2011 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
The start/ stop knob of my whirlpool washer LSQ9564JQ0 just spins. I have to deeply press against the larger part of the timer to move the arrow to the wash settings. I will still start and stop though....
The threads either on the timer knob (part number 3364291) and the timer dial ( Part number 3957849, the larger part of the timer with arrow) are worn. Pull the knob off and inspect the threads. Replace the part with the worn threads.
Jun 08, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Sep 17, 2009 | Kenmore 62602 Electric Dryer
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
