Question about Maytag MAV4755 Top Load Washer
My MAV7256aww is making a horrible noise. Replaced water pump and belt after appliance tech came out and said that was the problem. There was also a white fibrous powder under the washer and also inside around the part that the springs attach to.
  • wrecker3 Aug 28, 2010
    is this an easy part to replace? I have heard horror stories about taking the transmission apart due to the spring.
    Would the brake make noise even when the washer is in the spin cycle?
  • 10,865 Answers
Hello. It sounds like the transmission has gone bad on your machine. This is a big and expensive repair. If your machine is over 3 years old you may want to stop repairing and replace it. J.
Posted on Aug 28, 2010
  • 4,059 Answers
I think the brake shoes are worn out and it's now rubbing metal to metal.Your brake parts are shown in this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48140&diagram_id=663461#d663461
1995 Geo Prizm Charging System Light is on and my power steering is out. Help, I need to learn how to fix it, since I am unemployed. Evelyn
the belt fall off, open hood, gander. and bingo. belt loose or missing.
there can be 2 belts. if the water pump belt is bad the engine burns up. replace all belts there, using GY gator belts for max life.
or Gates belts.
Oct 12, 2013 | 1991 Geo Prizm
Replaced serpentine belt in my 1998 grand prix/ when i started it it made a HORRIBLE whole buncha noises, squealing mostly.any idea what is wrong now?
Spin all the pulleys by hand. Is one ready to fall off or frozen. Is the water pump pulley sloppy? Has the water pump been leaking?
Aug 07, 2012 | Pontiac Grand Prix Cars & Trucks
Timing chain making noise after water pump replasement
Basically its said,that when water pump is replaced,its also advisable to replace timing chain.The timing chain is either worn out or while replacing water pump,the timing chain got misaligned.It has to be inspected.Most probably,it needs to be replaced.
Below is the master help link provided to go through belt routing diagram:---Timing belt,timing chain, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Feb 27, 2012 | 2002 Dodge Stratus
This water pump is making funny noise how can i solve this
A water pump on any auto making noise is a sign of bearing failure on the water pump drive stem. The only remedy is to have the water pump replaced or replace it yourself. The bearing gets water intrusion or dries out and the bearing fails. The water pump is not expensive but labor costs can be substantial depending upon the location of the water pump. Many water pumps are driven by the timing belt on smaller cars. Gaining access to the water pump often involves removing the timing belt cover and the timing belt. Failure to reinstall the timing belt in the exact same position as it was removed can cause catastrophic engine failure. Without your vehicle make and model this response is generic most vehicles.
Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Renault Le Car Cars & Trucks
Washer is making a horrible sound while draining water from tub
if horrible sound is while drainpump is draining but before washer starts to spin either obstruction in drain pump or impellar on pump is bad and the complete pump needs replaced... if noise is while spinning the spider support is cracked which is very exstensive repair and dont reccomend repairing unless you have a couple of hours for dissasembley and reassembley...
Jan 24, 2011 | Samsung WF337AA Front Load Washer
2004 gmc envoy. has a 6cyl and a serp belt. the center pully off set to the left (i think its a water pump) has a bad wobble and making a horrible noise. Not over heating and no leaks. should i just change...
If the fan is attached to it than it is the water pump making the noise and it will need to be replaced. If the fan clutch is not attached to it than it is either the idler pulley or the tensioner pulley. The tensioner is on the passenger side (left) of the front of the motor.
Oct 07, 2010 | 2004 GMC Envoy
I have a Maytag washer that the agitator is not working , I makes a squealing noise, How do I repair this? Thanks
Your problem may be a seized water pump with the motor turning the drive belt on a water pump pulley that is not turning (belt squealing). Or the noise could be originating from a water pump that has a noisy/bad bearing. If the pump pulley is turning and making the noise, you may be able to lubricate the pump shaft with some quality shaft lubicant (no guarantee that the noise will cease)! If other problem, contact an appliance service company.
Feb 20, 2010 | Maytag Washing Machines
Maytag MAV4755 Top Load Washer Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
