Question about Maytag Dishwashers
We need some black filler strips for our new maytag dishwasher
2 Suggested Answers
  • 111 Answers
SOURCE: new ge908 slide-in range
The 30" is the widest you can get. I suggest getting a piece of stainless steel and having a metal shop cut and smooth the edges
Posted on Dec 20, 2008
Need a new utensils basket for my Maytag Dishwasher
I am very soprry but we do not have parts here at fixya.
Oct 10, 2012 | Maytag 23.875-Inch Built-In Dishwasher...
The soap dose not dispence
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it
Oct 20, 2010 | Maytag MDB3100 Dishwasher
Water is coming up through the kitchen sink when dishwasher is running and teh soap depenser will not release the soap.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these. Please do rate this solution and revert for further assistance.
Daniel
Aug 14, 2010 | Maytag Dishwashers
Soap dispenser won't open during operation
Hi
Daniel
Aug 02, 2010 | Maytag Dishwashers
Hi Expert, I have Maytag MDB5600AWS dishwasher. From last few days, I get the white sand like residue in all the containers - cups, glasses, pans etc. What would be the reason for it? thanks.
i have seen alot of these that get a stripped out wash impelle. they have a new seal kit and impellerfor these and it seems to be pretty common.
the kit has the install tools and instructions to do it properly.
take the pump apart from the top and see if the impellers look worn or stripped out.
Dec 31, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag MDB7100AWB dishwasher. 'High Current' during wash cycle. What do I need to do? Thanks
What problem is the "high current' you mention causing?
Many dishwashers continue to heat the water to a higher temperature to wash and rinse the dishes with. They turn the heat strip on to do this, which causes the dishwasher to pull more current.
Dec 16, 2009 | Maytag MDB7100AWB Dishwasher
New ge908 slide-in range
Dec 20, 2008 | GE Profile 30" Slide-In Gas Range -...
Maytag Dishwasher will not start. all lights will flash except for the start / cancel button.
I had the same problem. The plastic wiring strip that connects the touchpad had corrosion from water. The panel would need to be replaced, because they don't sell the touchpad separately. (around $50 - $70 USD)
Apr 15, 2008 | Maytag Dishwashers
Dishwashers Logo
138 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
