Question about Amana Heating & Cooling
The power cord GFI keeps tripping. I visually inspected inside the unit and nothing seems to be shorted or burned?
  • 70 Answers
Does it run long or on and off. It could be a bad cord, try a diffrent outlet.
Posted on Aug 28, 2010
How do I troubleshoot my LG refrigerator model:LFC20760ST that has stopped working?
Disconnect the power cord wires on the fridge side after you unplug the cord....for continuity on each wire.
Jan 28, 2017 | LG LFC20760ST Stainless Steel Bottom...
No power to wall unit
Have you tried plugging anything else in?
Also does the cord have a GFI breaker on it, or is the outlet a GFI outlet, if those are tripped it will keep power from going to the unit. If they tripped more then likely they got wet, or there is a short circuit.
Otherwise if all that is good circuit breaker would be next to check.
Aug 19, 2013 | Fujitsu Heating & Cooling
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Machine short
Two possibilities:
There is leakage in the internal wiring to the safety ground OR the unit is generating a transient current in the ground that trips the GFI. This is NOT uncommon for some motor driven appliances.
AS A test, put a ground isolator (3 wire to 2 wire plug adapter) on the cord before plugging in.
IF that seems to prevent the trips, then use an OHMMETER to test the resistance from each of the power wires to the Ground pin. It should be near infinite resistance. IF NOT, then there is leakage in the unit, PROBABLY contamination that is causing the electrical leakage current and the unit should be serviced.
Should the ground isolator appear to fix the problem, this means that this device CANNOT be operated from that type GFI due to transients it creates. You can try a new GFI that might be less sensitive OR put a line filter in the power cord.
Jan 13, 2010 | Rancilio (RAROCKYND) Grinder
My 48" Viking Range top trips the GFI
One leg of the power is "dead shorted" to ground. Use a Multimeter and start looking/testing to determine which component is bad.
Aug 31, 2009 | Viking VGIC3074 Gas Kitchen Range
Kicks off imediately ground faught on karcher pressure washer
This is a serious situation. It means there is a short circuit somewhere. You need to have a certified technician or electronics person look into it.
Aug 21, 2009 | Karcher 1750 psi Electric Pressure Washer
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Oct 03, 2007 | Waring Pro WC1000 Coffee Maker
Heating & Cooling Logo
110 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
