The problem with my NEC 68T90 TV is that the screen resolution is not correct. At 4:3 ratio, I can't see the sides of any video or TV program that I'm watching. Is there a problem with the hardware?
  • 55 Answers
Try adjusting the Horizantal size of the raster,if there is any control given for it on the back of TV.
Posted on May 09, 2008
    Scholar:
  • 52 Answers
The 68T90 is not an HDTV, and does not have an "Aspect" button on the remote. This is a normal SDTV (standard def) TV, seemingly made for European markets. Owners Manual
In the TV menu, there is this:
FORMAT
Picture format selection.
Select picture format between :
- 4/3: normal size
- 16/9: 16/9 size
- Zoom : expanded picture
In "Normal size" mode, with standard 4:3 video source images, you will always lose some of all edges of the image, due to what's called "overscan". This is an ancient process that causes a small amount of the original picture (typ. 2-3%) to be lost. In the early days of analog TV's, this was good, as it prevented the edge of the scan lines from being seen, which would look bad.
With the advent of HDTV, all signals are broadcast and received in digital, and is therefore totally predictable as to what will be seen... you will rarely lose even 0.5% of the image on a good HDTV.
However, having said all of that, if you are losing a significant portion of the left/right sides of the image, your horizontal deflection circuits may have gone bad. Watch for a commercial with a large circle, if it's significantly "out of round", then yes, you have "hardware" problems.
Posted on May 08, 2008
Try the aspect button on your remote, or if you have this hooked up to a cable or satellite converter, there are screen resolution preferences, you can change the screen resolution here, go the the menu portion and look for video/audio field
How can I change the screen size on my emerson 55 in tv with my remote contrl
Try:
1. Open the Main Menu (which is by the way the left arrow)
2. Choose settings
3. Press ok
4. Choose Television and press the right arrow 6 times
5. Choose view all and press ok
6. Choose Screen Aspect Ratio and High Definition and press OK
for this step you will need to know what type of display you have:
If you have a...
4:3 standard definition for an ordinary TV
Widescreen standard definition for a widescreen TV (16:9 aspect ratio) that doesn't display HD
720p on high-definition screens for an HDTV with 1280 x 720 resolution
1080i on high-definition screens for an HDTV with 1920 x 1080 resolution
1080p on high-definition screens for an HDTV with 1920 x 1080 resolution and progressive scan (also known as "Full HD")
I can't really help you with this, try looking in the maunal, but you can test it by...
7. Choose continue and press ok
8. On screen instructions will be shown on how to test your resolution
I hope this helps!!
Mar 30, 2017 | Emerson Televison & Video
Only able to receive small pictures on certain channels broadcasting some older programs.adverts and most programs are ok,but selected few are not?
Most television advertising and broadcasts today are in 16:9 aspect ratio. This is why they seem alright. However, older TV shows will still show up in their native 4:3 ratio since they were recorded that way. You may be able to force them to 16:9 ratio, but although they will now be full screen, their images will be distorted in the horizontal plane. Most TVs are designed to auto-adjust to the 4:3 resolution to prevent this distortion.
Jan 25, 2015 | Humax Televison & Video
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
I connected my media center PC to my new Sanyo DP50740 50" Plasma Television using the PC input on the back of the television. The instructions say that it supports 1360X768 with a 16:9 aspect ration...
No,13060 resolutions will not support by some tv correctly,will shift whole picture about to 6 inches to the right.That why,must use the PC Control panel to adjust to 1024 for the video to center.For the wide aspect 16:9 ratio,just find another aspect ratio to for expandsion to fit the entire screen.
Feb 05, 2011 | Sanyo Televison & Video
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
The image leaves about 2.5 inches not used on each side of the monitor.
The bands are caused by the monitor displaying a picture that is not the correct resolution. This model has a native resolution of 1920 x 1080 according to LG - see http://www.pcworld.com/reviews/product/124873/review/w2353vpf.html#specs When you have your video card set to a different resolution that this the monitor tries to adjust the display to best fit the screen. The native or default resolution is 16:9 or wide-screen and if you have the video card displaying at 4:3 then you will have the blank bars displayed. Go to display properties and change your resolution to one that is 16:9 ratio and the bars should fill out.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 29, 2010 | LG W2353V-PF 23' LCD Monitor
Picture size/aspect ratio in HDTV and upconverting DVD
In the digital world, you can't have a 4:3 aspect ratio DVD title (720x480) on a 720p (1280 x 720) / 1080p (1920x1080) display without some kind of centering or stretching to some extent. (square vs rectangle) Now, on a 16:9 aspect ratio title (wide screen format) you should have any scaling issues regardless of the pixel resolution. Despite what the sales person told you, trans-coding ("upconverting") lower resolution titles to a higher resolution does not increase the quality of the image. Any attempt to do so would be only to try to reduce block noise and any kind pixelation at higher resolutions. (blurring square pixel blocks)
In the analog world, the quality of the image is based on the encoder and signal depth. If your TV excepts HD analog, you might be able to have your cake and eat it too. That would force your display to convert an analog signal into a digital resolution, letting the TV hardware do all the trans-coding. Manufactures are completely phasing out analog signal receiving, but might have the RGB RCA connectors for backwards compatibility. Eventually, it will not be supported and you will be forced to buy higher resolution content.
Mar 31, 2017 | Televison & Video
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
