Question about Air Tools & Compressors
Air compressor will not start unless reset button is pushed. It will run for about a minutes and then it kicks out again. To start it you have to push the reset button again.
  • 3 more comments
  • Jeff
    Jeff Aug 31, 2010
    Is this the reset button on the motor or on the pressure switch?
  • landacrek Aug 31, 2010
    On the motor
  • Jeff
    Jeff Sep 01, 2010
    What is the make and model of your compressor? I can think of two compressors that have weak motor reset buttons.
    If your unit takes oil check the amount of oil in the compressor.
    One more question, If you leave air in the tank overnight does it lose pressure?
  • landacrek Sep 02, 2010
    It is a Task Force. It does not take oil and it has always lost pressure when air was left in it.
  • landacrek Sep 04, 2010
    It is a Task Force. It does not take oil and it has always lost pressure when it sat overnight.
Buffalo12980
  • 625 Answers
SOURCE: Unit will not blow cold air after starting up for first time this season
you may need to remove the rear cover to examine what is and is not running. once you remove the back, start up the unit on a workbench. see if the fan is running and the compressor has kicked in. look at the larger or two tubes coming out of the compressor. if it is cooling a small layer of frost or condensation will appear on this " suction" line. if this tubing and the other one are approx the same temperature, then there is a freon leak in the system. Only an EPA certified technician can fill your unit. I am not familiar with that RED button but it mat be a reset of some sort. With the back removed see how it is connected in the wiring circuit. if you have the wiring diagram, please send it to me under my regular email address and I'll walk you through the troubleshooting procedure.
Posted on Sep 02, 2007
SOURCE: Push the reset button
Dude, I have the same problem.Whenever I am getting ready to film, and I also have a Panasonic MiniDV camcorder, it will Say PRESS THE RESET BUTTON. I also have the same problem about the cassette holder, for it won't open. I don't know what the hell is going on with it. I have a model PV-GS9.
Posted on Jan 12, 2008
SOURCE: Panasonic Mini DV NV-GS11EG "push the reset button"
I also have the same problem but no solution. Howevever I suspect it is related to the tape drive because initially I could resolve it by changing the tape. Now it just wont close the tape door so I don't know what to do next. Please help !!
Posted on Nov 03, 2008
SOURCE: I have a Panasonic PV-GS14 and it ALWAYS says 'Push Reset Button'
I had the same problem. In desperation, I picked up my trusty can of compressed air and aimed a few shots into the recorder/playback mechanism. Worked like charm.
Posted on Apr 04, 2009
louislevel_2
  • 374 Answers
SOURCE: DeWalt emglo compressor does not start
hello,
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 psig.so after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur switch.you have defective pressure switch,regards rate me,thanks
Posted on May 02, 2009
2003 Pontiac GT1 3.4
Not exactly.
The compressor can run until it begins to freeze up depending on the system, or until pressure readings get too high or too low.
Most cars today are designed to run the compressor as long as the switch is engaged and just add hot air from the heater to adjust cabin temp. There is a sensor in the evap to prevent the system from freezing up.
As long as it is warm outside and the system is not freezing up then yes the compressor will run constantly.
Jul 04, 2012 | Cars & Trucks
The compressor will not kick on i took the cover off and the compressor is hot will it reset it self or is there a reset button on it somewhere it was running fine just 1 hour ago any suggestions
it has an overload on the compressor that has kicked the compressor out and will not let it start back up,,,let it cool for a bit then try again it will reset it's self,,,,, make sure that both sets of coils on this unit are clean....you see the condensor coils when your on the roof with the cover off... check the inside evaporator coils as well..... let me know what you find out......
May 10, 2011 | Dometic Rooftop RV Air Conditioner
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Makita 5200 Mac doesn't run
one of two things, either you have a bad start capacitor on the motor or a defective start switch inside the motor, either one can be checked at a electric motor shop
Dec 12, 2009 | Makita MAC5200 Electric Powered Air...
The air conditioning takes to long to come on. where is the reset button?
usually a new aircon in its start up stage takes about 2 - 4 minutes before it runs, and then the compressor kicks and all is normal. after a few weeks the system will start normally. there are no reset button but the power button.
I hope this helps.
Jun 13, 2009 | Heating & Cooling
IR T 20 air compressor will not kick on
IS IT THREE PHASE OR SINGLE PHASE? MOTOR TAG WILL SAY PH 1 OR PH 3.DOUBLE BREAKER OR TRIPLE BREAKER WILL ALSO TELL. IS THIS A BRAND NEW INSTALL OR AN EXISTING COMPRESSOR THAT JUST NOW STARTED DOING THIS. SOUNDS LIKE A POWER PROBLEM LIKE A MISSING PHASE OR BLOWN FUSE. REMOVE FUSES WHEN OHM CHECKING - DONT TEST THEM WHILE STILL INSTALLED.
Mar 14, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
415 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
